Question about Samsung Heating & Cooling
I have a samsung biotech plus which is leaking water from the vents in the front. The unit was already in the home when we purchased. Cools beaut but the water is a pain. Can anyone suggest an answer please?
  • katrina702
    katrina702 Jan 15, 2012
    Us too, the exact same thing has happened to our Samsun Bio Tech. Did you find a solution??? katrina@bizzpro.com.au
  • 2,133 Answers
Check your air filter & evaporator coil for dust blocked. Clean it.Even if less rpm of blower motor is also one of the problem. Replace the capacitor.
Posted on Dec 30, 2010
I have a Samsung Biotech plus air conditioner - Model SC12ZAB. When the system is turned on, all the lights on the control panel light up and it is not possible to select any of the 5 sway options to...
warranty? go that route. Id unplug at least a minute see if it's brain will reset. With these new fangled computerized machines, one needs to be a specialist's specialist. Hopefully you have your owner's manual, it has a troubleshooting section, no help? Call the Customer service they are usually helpful, Or email them too.
Jan 10, 2013 | Samsung Heating & Cooling
The machine leaks water from the bottom of the unit at the beginning of the wash cycle. I just purchased the unit, new, from a big box store. All hoses are tightened properly, and the outlet hos is secure.
you need to turn the water pressure down at the tap & adjust the front two feet to maximum height this is a very common problem for new front loaders no problems just adjust & it will be fine.
Jan 13, 2011 | Samsung Washing Machines
Over heats , and has lots of moisture vapor coming out of the bottom.it dries and everything ,but its like it's leaking water
The most likely cause is your home vent is clogged and the dryer has little or no air flow. The water is exiting the dryer with the air since there is little air flow which causes the "water leak". Clean your home vent all the way through and your dryer will probably also need a good cleaning. This should take care of the problem. Please rate this post.
Dec 14, 2009 | Dryers
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Jun 15, 2009 | APC Heating & Cooling
Pinging noise in duct work
it could be merely condensation or maybe the expansion and contraction of the metal as it heats up and cools down. if possible try insulating the vent if not done so already
Jan 27, 2009 | Aprilaire 700 Humidifier
Heating & Cooling Logo
286 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
