Question about Ovens
In the middle of cooking in my GE profile PB975 double oven w/ convection, the probe light began to flash and the oven turned off. I was not using the probe--it hasnt worked for a long time. I turned off the oven by the breaker for the night hoping it would reset, but when it was turned back on it is still flashing, and the clock didnt reset either, It is acting like The probe is inserted and I cannot use either oven.
  • 1 more comment
  • CheleD Dec 30, 2010
    I wouldnt even know how to begin to do that.
    I already tried to reset it as stated, i left the breaker off all night. I doesnt seem like it reset because the time kept going. seems like it should have flashed 1200 but it was 7 something. about the time i turned it off.
  • CheleD Dec 31, 2010
    Thank you! That is exactly what happened! I was roasting vegetables in the top portion of the oven (squash and mushrooms) there was a lot of steam going right up the probe receptacle. I will try your solutions. Those are the most helpful--not call a repairman, which I could have figured out myself! Thanks again :)
    Genius:
  • 1,456 Answers
Hello
The common cause of this problem is that grease or mist may have gotten into the probe socket,to clear this you will need to get a hair dryer and blow into the socket which is located on the right side under the metal circlular cap if the insulation is over saturated you might have to pull the oven and remove the side to dry it.
If the problem persists this means that either the probe jack or the wires going to the probe jack have shorted out thinking there is a probe inserted even though there is not.
You will need to replace the probe recepticle which comes with new wires to correct this issue. If you don't plan on using the oven probe, you can always clip the wires and tape the ends off as this will make it so that the board cannot sense the oven probe recepticle giving it a false reading.
Posted on Dec 30, 2010
  • Ovens Master
  • 19,396 Answers
Hi.
First remove the oven probe (ensure that oven is not hot first) and try resetting the oven. Trip the main circuit breaker to reset the oven. The light should not come on when the probe is not in.
If you keep getting the probe light with probe not in, that means that the contacts in the probe housing have melted and shorted. When this happens the electronic control keeps turning on probe light even when the probe is not in. In that case the probe housing must usually be replaced to fix the problem.
  • Ginko
    Ginko Dec 30, 2010
    Hi.
    RE:I already tried to reset it as stated, i left the breaker off all night.
    turned it off.
    Then you have a shorted probe housing and you must have it replaced. The problem is quite common after self cleaning is performed.
    I see tha you gave me negative feedback and you passed the question to other expert. That is not really great for the expert assisting you. Your choice by the way.
    Goodbye.
    G.
  • 4,323 Answers
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    To do this you need to take it apart....if you are not comfortable in doing this yourself then get a professional involved.
  • Daniel Scott
    That is the reason I told you that it is the sensor/control that is bad.
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
Apr 10, 2013 | GE Profile JT912 Electric Single Oven
I Lost the instructions for my GE profile Oven probe. Need advic
I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
Nov 25, 2009 | GE Profile JT952 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Lost my manual
Try going to http://genet.geappliances.com/DocSearch/Dispatcher and then type in JK955
Sep 30, 2008 | GE Profile JK955 Electric Double Oven
Never used Convection JTP 5650DI55
Did you try going to the GE website? If not, try it:
http://www.geappliances.com/
When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven bulb
i have a ge profile double oven and the glass cover on the top convection oven is held in place by grooves that latch onto the glass dome cover. Just turn the dome so that the handles on the glass dome cover are exposed. I used a flashlight and a screwdriver to push the dome to one side.
Dec 25, 2007 | GE Profile JTP56 Electric Double Oven
This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
Aug 21, 2007 | GE Profile JT915 Electric Single Oven
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
216 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
