Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My hotpoint ultima extra power stream washing machine wont spin when the drum is loaded, any ideas to what it might be?
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
Apr 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Washing machine motor not turning
hello,
what this indicate is that there have been a power disconnection from power supply on the jet string connected to the drum (drum controller)
what you will have to do to solve this problem is to unscrew the the washer then trace the wire down to the jet it is round in shape at the back of the washer
please rate this
thank you
Jul 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Will not spin.
could be a couple of causes.First take off panel at back of machine and check that belt is in place.
Has it been noisy on spin lately?
Jan 29, 2009 | Hotpoint WMA64 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima not spinning on a full load
may need reprogramming of the eeprom on the control board. can only be done by engineer visit. explain over the phone 1st you need reprogramming if not using hotpoint.
Jan 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima extra wma64
hiya
check the wires which run from the motor up to the main pcb, it's quite common for these to rub together and break. i have came across this a number of times now.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
