Question about Refrigerators
Why does the circuit breaker trickers off after about 6 -8hrs running
  • Refrigerators Master
  • 43,501 Answers
Compressor is going bad...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 30, 2010
Circuit breaker kicks off after 3 to 5 mimutes
call in a electrician to check insulation of the circuit
depending on the current requirements of the unit running, check the application of the circuit breaker as it may not be sufficient to run the unit --again an electrician will be able to determine the requirement
for example --if you are running a hot water system through that breaker and it is a 10 amp breaker then the hot water system may be running 10 amps which means that the breaker will overheat after time and switch off
it may require a 15 amp breaker to do the job--as an example
or if you have more than 1 unit using that breaker then the combined current usae is too high for the breaker
Feb 06, 2017 | Electrical Supplies
The dashboard and climate controls comes on when the key turned to accessory for about 30 seconds then fades out sand nothing works. It runs fine, all external running running light work fine as well
Check your circuit breaker and relays (owner's manual will tell you which breaker or relay is for the dash lights). You may have a "circuit breaker" that shuts off when heated and then starts up again when cold. Replace the circuit breaker with another one from the car and see if the problem. I solved, you have a bad circuit breaker. If that's the case, replece the circuit breaker. If not, you have a bad ground or short in the system, so get the system checked.
Dec 31, 2014 | 1993 Cadillac Fleetwood
I have 150A circuit breaker which controls the power to the daughter box on one side of my house This box runs a/c pool and heater I believe the neater shorter tripping the breaker. I've tried...
the line in order shouldn't be an issue as they run in series of 3 , it sounds to me like you just have a weak breaker that trips with little feedback, and isn't resetting correctly
Jul 03, 2011 | Fuji Ea203b 150a Circuit Breaker
Tyre presure for yamaha tricker
Hi, Mobyanster for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.louis.eu/rund-ums-motorrad/bike-datenbank/yamaha-tricker-250/xg250/1422
Yamaha MotorBikeSpecs net Motorcycle Specification Database
2005 Yamaha XG250 Tricker Service Repair Workshop Manual Download Download... $10
OEM parts for Yamaha
YAMAHA XG250 Owner Manual
Jun 24, 2011 | 2006 Yamaha Tricker
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
Breaker trips when running a small dehumidifier alone on circuit
the breaker is getting weak and won't hold the load, assuming that nothing else is on the line. if it trips immediately u could have a short.
Jul 11, 2009 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
