Question about KitchenAid Microwave Ovens
My kitchenaid series 600 (110v) suddenly lost power. What can be the problem.
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 30, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Got switched off suddenly and all panel lights got off
The main fuse is inside the cabinet near where the power cord enters. When everything goes dead all of a sudden, 99.9% of the time it's the fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 05, 2014 | KitchenAid KHMS2050SSS Microwave Oven
Homemaker microwave em930adf
WELL IT MAY HAD A ELECTRIC SHOCK..ITS COMES FROM THE POWER STATION...
TURN THE OVEN OFF AND LEAVE IT FOR A WHILE...THEN PLUG IT IN AGAIN AND SEE WHATS HAPPENED...
IF STILL THE PROBLEM...GO IN CONTACT WITH THE MAKER OF THE OVEN..ALSO MODEL NUMBER THEY MAY CAN HELP U FURTHER
Oct 18, 2013 | Microwave Ovens
I have kitchenaid microwave model 1857 wss it was working perfectly the night before and when in the morning I came to kitchen the microwave looked the it lost its power although I check all of the circut...
SEEING AS HOW YOU USED IT THE NIGHT BEFORE, THE PROBLEM SEEMS TO BE THAT YOU MAY HAVE BLOWN A FUSE OR A THERMAL CUT OUT (TCO) THERE ARE SEVERAL DIFFERENT FUSES IN THIS MICROWAVE. IF YOU'RE INTERESTED IN SALVAGING THE MICROWAVE BECAUSE YOU LIKE IT, I WOULD HIGHLY RECOMMEND CALLING A TRAINED PROFESSIONAL TO FIX THIS UNIT BECAUSE THIS UNIT IS HIGH VOLTAGE WHEN IT'S RUNNING AND HAS VERY HIGH POTENTIAL TO KILL YOU. BE VERY SAFE WHILE INSPECTING ANY FUSE FOR CONTINUITY (0OHMS OF RESISTANCE ON YOUR METER.) NOTE THAT SOME THERMOSTATS IN THIS UNIT LOOK LIKE TCOS.
Jan 24, 2013 | KitchenAid Kitchen Aid - KHMC1857WSS...
Our 2007 kitchenaid microwave, 1200 watts unit suddenly stopped working - it powers on as normal, but is not warming items as it should. Not sure what to do. Seems too new to kick the budket at this...
your wires going to the magnatron have probably have got loose and do not have a good connection, this is what I find on whirlpool/Kitchenaid microwaves
Feb 23, 2011 | KitchenAid Microwave Ovens
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
Feb 17, 2009 | KitchenAid KHHS179LSS Convection /...
Microwave no power
How can you take the fuse out on this model KHMS 155LSS-4 of kitchenaid
Jan 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
No power to the microwave
yes !! check the micro switches where the door latches , you have to open the microwave to check inside if switches are in their place or broken . hope it helps
Apr 22, 2008 | KitchenAid KHMS155L Microwave Oven
Khmc107b (not a bt): lost power, won't start again
The most likely causes are an open thermostat on your magnetron or the internal fuse. You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 The fuse is shown on diagram 5 and the thermostat on the magnetron is on diagram 8. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 25, 2007 | KitchenAid KHMC107BT Convection/Microwave...
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
