THE LIGHT DOES NOT SWITCH ON BUT HIGH BEAM FLASH STILL WORKING ALL FUSES ARE OKEY
    Problem Solver:
  • 5 Answers
Pera ko na wawala
Posted on Dec 30, 2010
Low beam headlights do not work 2010 chevy impala high beams work as do daytime running lights low beams do not work on either automatic mode or manual mode
The headlamps are controlled by the BCM - body control module , do you know what that is ? The headlamp switch is a input to the BCM ,the BCM energizes relays to turn on the headlmps , low beam relay , high beam relay , DRL relay . These relay's are PCB - printed circuit board relay's ( non - serviceable ) If found to be bad the whole under hood fuse box would need to be replaced .
Low Beam Headlamp Operation
The low beam headlamps may be turned ON in 3 different ways:
• When the headlamp switch in the HEAD position for normal operations
• When the headlamp switch is in the AUTO position, for automatic lamp control (ALC)
• When the headlamp switch is placed in the AUTO position, with the windshield wipers ON in daylight conditions, after a 6 second delay
Battery voltage is applied at all times to the coil and switch sides of the LOW BEAM PCB Relay located in the underhood fuse block. When the headlamp switch is placed in the HEAD position, ground from G202 is applied through headlamps ON switch signal circuit to the body control module (BCM), signaling the headlamps ON request. In response to this signal, the BCM applies ground through the headlamp low beam relay control circuit energizing the low beam relay. With the relay energized, battery voltage is applied through the switch side of the relay, the left and right low beam fuses, and the low beam supply voltage circuits illuminating the low beam headlamps. Ground for the left headlamp is provided at G101 and the right headlamp at G100.
Do you know what B codes are ? BCM - DTC'S - diagnostic trouble codes , need a factory scanner or professional one to view these codes , not autozone or advance etc....Having a qualified repair shop check your vehicle would be your best bet.
DTC B2575 00: Headlamp Control Circuit
Circuit/System Description
The vehicle headlamps are controlled by the body control module (BCM) based on inputs from the headlamp switch and the turn signal/multifunction switch. The headlamp switch has four positions: Off, Auto, Park, and Headlamps. The default headlamp switch position is Auto, in which the BCM uses the ambient light sensor to determine when headlamps are needed. The Off portion of the headlamp switch is a momentary switch which overrides the automatic headlamps and will turn off the vehicle headlamps. When in the Off position, the headlamp switch grounds the headlamp switch headlamps off signal circuit, prompting the BCM to turn off the headlamps. The Park position of the headlamp switch will only illuminate the vehicle parking lamps. The Headlamp position of the headlamp switch will illuminate both the parking lamps, as well has the headlamps. With the headlamp switch in the Headlamp position, the headlamp switch headlamps on signal circuit is grounded, prompting the BCM to turn on the headlamps, regardless of other factors such as ambient light.
The headlamp high beams are controlled through the flash to pass switch and the headlamp dimmer switch, both located in the turn signal/multifunction switch. The flash to pass switch is a momentary type switch, designed to illuminate the high beams as long as the switch is held. With the switch closed, the flash to pass switch signal circuit is grounded, prompting the BCM to turn on the high beam lamps. The headlamp dimmer switch allows the operator to select between full time high or low beam operation. Unlike the flash to pass switch, it is not a momentary switch. When the headlamp dimmer switch is in the high beam position, the headlamp dimmer switch high beam signal circuit is grounded. This prompts the BCM to turn on the high beam lamps.
The BCM controls the headlamps based on the inputs explained above. When a low beam request is received, the BCM grounds the headlamp low beam relay control circuit. This energizes the coil in the LOW BEAM PCB relay, causing the relay switch to close. This then applies B+ to both low beam headlamps through the LT LO BEAM and RT LO BEAM fuses, illuminating the low beam headlamps. When a high beam request is received, the BCM grounds the headlamp high beam relay control circuit. This energizes the coil in the HIGH BEAM PCB relay, causing the relay switch to close. This then applies B+ to both high beam headlamps through the LT HI BEAM and RT HI BEAM fuses, illuminating the high beam headlamps
Mar 12, 2018 | Cars & Trucks
Headlights not working on 2003 alero/all other lights working/checked fuse and changed relay
Here is how they are suppose to work .
Headlamps
The headlamps may be turned on two different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the OFF position, for automatic lamp control (ALC). During ALC, the headlamps will be in day time running lamp (DRL) operation in daylight conditions, or low beam operation in low light conditions. The LH HDLPand RH HDLP fuses, supply battery positive voltage from the underhood junction block to the left and right headlamps. The circuit continues through both low and high beam lamps, then back to the underhood junction block. The low beam and high beam circuits continue to the headlamp switch. The low beam and high beam circuits also provide the body control module (BCM) with both low and high beam inputs. The headlamp switch includes the dimmer switch and the flash-to-pass switch. When the headlamp switch is placed in the HEADLAMP position a path to ground is provided. Ground is provided at G201. Depending on the position of the high/low beam switch, either the low or high beam circuit will now have power and ground.
The LH HDLP fuse in the underhood junction block, supplies battery positive voltage to the automatic lamp control (ALC) headlamp relay coil circuit. The ALC relay switch circuit is connected to the low beam circuit at the headlamp switch. When the headlamp switch is placed in the OFF position, the BCM will automatically turn on the low beams in low light conditions. The BCM energizes the ALC relay, closing the switch contacts and grounding the low beam circuit. Ground is provided at G201. With the headlights in the low beam position, the high beams may be momentarily turned on or flashed with the dimmer switch handle. The flash-to-pass feature is accomplished by pulling the dimmer switch handle toward the driver. The headlights may be switched to high beam with the opposite movement of the dimmer switch lever. When the headlamp dimmer switch handle is pulled toward the driver, the flash-to-pass switch closes grounding the high beam circuit. Ground is provided at G201. Both high beams will remain on until the driver releases the switch handle.
If the driver places the headlight switch in the HEADLAMP position , the headlights will remain on until turned off or the battery runs dead.
Finding a wiring diagram to use along with a DMM - digital multi-meter (voltmeter ) To test the electrical circuits for the headlamps B+ power & ground side of the circuit is the way to find a fix .
Watching a few basic electrical testing video's on youtube may help you .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
The Trainer 18 Electrical Testing Tips
Can take years to learn how to trouble shoot automotive electrical systems properly .
Nov 21, 2017 | Cars & Trucks
Left operating headlight not working
the switch supplies power to the relays that switch on the lights according to the position you have it at
so on high beam there will be 2 high beam lights working
on low beam there will be 2 low beam lights working
back to passing lights or flashing head lights , both beams will work so the switch is the last item to consider
Now with only one side beam not working it comes back to the ground on that light for that bulb
remember that electricity follows the path of least resistance so it the ground is bad the current will ground out through another point including a light which will switch that light off or make it not work
remember the brakes light that flask when an indicator is used --same thing
Jan 24, 2016 | 2000 Nissan Maxima
2002 f-350 headlights not working. new mfs, new headlight switch, no power to fuses
Did you check fuse # F2.7 in the central junction box ? This fuse powers the main light switch an the MFS an the headlamp fuses ! Does your truck have auto lights ?
Jun 22, 2015 | 2002 Ford F-350 Super Duty
Why wont the headights or running lights work on my 2002 Buick LaSabre?
There are several reasons why your headlamps an running lights don't work , the headlamp switch is a good one ,plus relays an the DIM - dash integrated module an associated wiring ! Here is how the headlamps work , right out of Buick factory service info !
The dash integration module (DIM) provides battery positive voltage to the signal circuits of the headlamp switch. The signal circuits include the headlamp switch headlamps on signal, the flash to pass switch signal and the high beam input. With the headlamp switch in the ON position, a ground path is available for the headlamp switch headlamps on signal circuit of the DIM through the headlamp switch. The DIM provides ground to either the headlamps high beam relay control circuit or the headlamps low beam relay control circuit of the low beam circuit. The position of the headlamp dimmer switch determines which relay control circuit has ground. The DIM supplies battery positive voltage to the relay control circuits, if the headlamps are necessary. The fuse block - underhood supplies battery positive voltage to both relay switch circuits. When the low beam relay control circuit is energized, current flow is to both low beam fuses and to the low beam headlamps. The headlamps have ground at G103 and at G401. When the headlamp high beam relay control circuit is energized, current flow is to both high beam fuses and to the high beam headlamps. The high beam circuit is divided into a left and right side circuit. The current flow of the left high beam is from the fuse to the left high beam lamp. From the lamp, the current flows to the normally-closed contact of the DRL relay to G103. The current flow of the right high beam is from the fuse to the right high beam lamp. From the lamp, the current flow is to ground at G401. When the headlamp dimmer switch lever is pulled toward the driver, the flash-to-pass switch closes. This grounds the DIM flash to pass switch signal circuit. In response to this input, the DIM energizes the HDLP HI BM relay. Both high beams remain on until the driver releases the switch handle. If the low beam headlamps were on during a flash to pass operation, the low beams remain on. The headlights may be switched to high beam with the opposite movement of the headlamp dimmer switch lever.
By running lights , do you mean park lamps or day time running lamps ?
Park, Tail, License and Marker Lamps
The park lamps, including the license lamps, are turned on when the headlamp switch is placed in the PARK or ON position or anytime the headlights are requested. The fuse block - rear supplies battery positive voltage to the switch contacts of the Park LP relay. When the headlamp switch is in PARK or in ON, the park lamp switch on signal circuit of the DIM has a ground path. The DIM provides battery positive voltage to the control circuit of the Park LP relay. When the park lamps and/or the tail lamps are ON, the DIM energizes the park lamp relay control circuit. This closes the switch contacts. Current flows from the Park LP relay to the LH PARK LP and the RH PARK LP fuses. From the fuse, the current flows to the park lamps. The left park lamps are grounded at G103, G401 and G402. The right park lamps and the right tail lamps are grounded at G103 and G401. The DIMR fuse supplies battery positive voltage to the license lamps and to the DIM instrument panel lamp fuse supply voltage - 1 circuit, for interior lamps dimming. The license lamps are grounded at G401.
The best advice I can give is that you take this to a ASE certified professional repair facility unless your a qualified automotive electric repair person !
Diagnostic Starting Point - Lighting Systems
Begin the system diagnosis with the Diagnostic System Check - Lighting Systems . The Diagnostic System Check will provide the following information:
The identification of the control modules which command the system
The ability of the control modules to communicate through the serial data circuit
The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
The
Mar 15, 2015 | 2002 Buick LeSabre
The low beam lights do not work I have tried a new bulb and replacing the fuses. the high beam lights do work
You may have to check a few items here. Do the high beam lights only work when you "flash" from the combination stalk or do they work when you have headlight switch turned on and then select high beam from stalk..? You may also want to check out the headlight relay. If this is OK, you might have a headlight switch issue or the combination stalk may be faulty.
Feb 28, 2010 | 1984 Porsche 944
2002 BMW 330XI, high beams do not come on fully when switched to on. Momentary on then off. But they do come on when you flash to pass. low beams and fog lights work good. Any help would be cool! Thanks
check fuse and relay, if its good, than you have faulty switch, only work on low but not high beam, to turn high beam on the switch move forward which is fauty or no contact, flashing high beam move toward you which has a good contact and working. it two switch in one unit.
Sep 25, 2009 | 2003 BMW 330
1994 ford f-150 with day time running lights headlightnot working
Daytime Running Lamps
The daytime running lamp (DRL) system is designed to turn the high beam headlamps on, with a reduced light output, and without illuminating the high beam indicator lamp in the instrument panel. You have a DRL Module.
The multifunction switch is the stalk on your column.
This is 96 F150 circuit. Don't have 94.
Symptom Chart, Headlamps HEADLAMPS Condition Possible Source Action
  • Headlamps Inoperative
  • Circuitry open/shorted.
  • Damaged headlamp switch.
  • Blown fuse.
  • GO to Pinpoint Test A .
  • Headlamps On Continuously
  • GO to Pinpoint Test B .
  • High Beams or Low Beams Inoperative
  • Damaged multi-function switch.
  • GO to Pinpoint Test C .
  • One High Beam or One Low Beam Headlamp Inoperative
  • Damaged connector.
  • Headlamp bulb damaged.
  • GO to Pinpoint Test D .
  • Flash-to-Pass Inoperative
  • Blown fuse.
  • GO to Pinpoint Test E .
Feb 25, 2009 | 1994 Ford F150 Styleside Supercab
My headlights dont work,.all other lights are fine though,.is it the fuses or the bulbs? im not sure what fuses they would be,.there seem to be different ones for the same thing
do your flash to pass lamps light when you pull the stalk towards you? If yes, the bulbs are ok.
Do the hig beams work?
Your headlamps have sepaerate fuses for each headlamp and you have a low beam relay and a high beam relay under the hood in the black box.
If everything is out, I suspect a bad headlamp switch.
Check car-part.com and look on page with * for cheapest price.
Your owner manual will identify fuses & relays.
PS, You did not recently instal high current bulbs did you? If yes, put originals back in.
HEADLAMPS
The voltage is supplied to the lamp switch through a fuse. This fuse is located in the central junction box in the left-hand footwell.
When the headlamps are switched on, a voltage is supplied to the high beam/low beam switch and to the low beam relay. The relay for the low beam is located in the battery junction box (BJB) in the engine compartment.
If the high beam/low beam switch is set to "low beam", then a voltage is supplied through the low beam relay to the low beam part of the headlamp assembly. The left and right-hand low beams are fused separately. The fuses are located in the battery junction box (BJB) in the engine compartment.
If the high beam/low beam switch is set to "high beam", then a voltage is supplied through the high beam relay to the high beam part of the headlamp assembly. The left and right-hand high beams are fused separately. The fuses are located in the battery junction box (BJB) in the engine compartment.
Lamp Switch
Removal
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
    Remove the lower driver's side footwell trim.
  1. Detach the lamp switch bezel.
    • Remove two screws.
  1. Remove the light switch.
    • Remove three screws.
    • Disconnect the electrical connector
Feb 23, 2009 | 2005 Ford Focus
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
