Question about Kitchen Ranges
My cord keeps braking on my shower,it doesnt snap it just goes really tight and wont work anymore,im having to change the switch a few times a year.
    Problem Solver:
  • 5 Answers
Pohtos
Posted on Dec 30, 2010
How to start ozito petrol chainsaw
1.fill with bar oil an 2stroke petrol
2.put the chainbrake on
3.if there is a primer bubble 5-10 pushs might say next to bubble
4.IF YOUV\'E NEVER STARTED A CHAINSAW PUT IT UPRIGHT ON FLAT GROUND and put you right foot as far in the trigger handle as you can, put enough weight to stop the bar or chain touching dirt, dirt will blunten a chain very quickly
5.grab the top bar with left hand firmly
6.pull out or raise the choke the whole way.
7.switch on the on/off switch
8.make sure your as much weight on your hand an foot holding the saw and pull the cord fast but never the whole way out or else it will snap over time and when it cant come out anymore it will jerk the chainsaw which can make the bar hit dirt and your chain will get blunt!!! or your leg but that wont blunten the saw
9.keep pulling the cord until you hear the engine fire,
Probably 3-5 descent pulls, it just revs a little loader and longer.
when it fires push the choke back in the whole way
10.pull the cord a few more times and it will start up dont pull the trigger till youv\'e taken the chainbrake off, or youll burn out the clutch. dont forget dont let the chain touch dirt a blunt chain makes cutting really hard on you and the saw.
If you know how its worth stopping and sharpening it as soon begins to lose its edge your back will love you for it, and you get more wood cut. But if you dont sharpen evenly and at the right angles it can be as bad as hitting dirt because it wont cut straight and get stuck
Jul 09, 2014 | Garden
Horn tail light and blinkers wont work
Check the fuses ...sounds like you may have fried one or two, Also that is a very tight fit where the brake light switch is....make sure you are not grounding out in the bars where the switch fits in the groove
Jan 11, 2013 | Harley Davidson XL Sportster 883...
Loower looper keeps braking.
Sergers are... well can be a pain. "Lower looper thread keeps breaking." Ok... so Here is what I Would do. Get your magnifying glass out and really get in close with a good light and look for burrs on the looper. Also look for burrs on the throat plate, etc. If you find one use some very fine sand paper and carefully smooth it off.
If that doesn't help or fix it. Take it in to a repair shop and tell them what's going on. you might need it timed too. Good luck
Dec 20, 2012 | Brother 1034D Mechanical Sewing Machine
2004 Dodge Dakota Quad Cab: The brake lights wont light up at the rear of the truck and the Center High Mounted Stop Light wont turn off.
Im having the same issue on my 04 Quad Cab Dakota. Changed out the brake light switch but still no brake lights. You have any luck ?
Oct 09, 2010 | 2000 Chrysler Concorde
My cruise control doesnt work
First check the brake switch if it is sending a signal that the brake is applied the cruse cont. wont work. If the vehicle is a standard then also check the switch on that pedal for the same reason. I don't really know what you mean by "the gas light" do you mean the light behind the gauge or?
May 08, 2009 | 2001 Toyota Tacoma
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Akai TV not working
Does the sound not work either? If it does then the backlight in your lcd screen has went out and your better off buying a new one because it is more than the tv is worth to fix it. Just start running through the imputs with about a 5 second pause between as this tv takes a few seconds to switch imputs and make sure you have cable or something connected to it the imput button is the second one down from the power button on the bottom right side of the tv. But if you dont have sound and it just seems completly dead most likely it probly got hit by lightning and slowly quit. Or maby you need to just buy a power supply if you dont see the green light anymore. Worst case senario your tv just got up and quit or maby it burned it self up from getting to hot. You can get a power supply on ebay for as cheap as 34.99. Hope this helps.
Aug 05, 2008 | Akai LCT2070 20 in. EDTV-Ready LCD...
Possible PSU problem?
sounds like a bad power supply to me.
Oct 21, 2007 | Gateway GT4016 Desktop PC
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
