Question about Watches
Leaked in swimming pool stopped, says on back water proof 100m not resistant.
    Problem Solver:
  • 5 Answers
+6025
Posted on Dec 30, 2010
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
Are fossil 10 atm watches water proof?
No watch is "water proof." As a matter of fact, there's a U.S. law on the books that watches (and other equipment) can only be described as "water resistant," since nothing other than a solid object can completely shed water.
All that said, the 10 ATM designation is meant to convey that when the watch was new, it was supposed to withstand up to 10 atmospheres of external pressure--which would translate into being about 300-330 feet underwater. That's pretty water proof in my book.
HOWEVER, and this is a big caveat, a watch's water resistance rating is based on its condition at the time that it left the factory. Over time, the little gaskets that help keep water out of the watch will begin to wear and provide less water resistance. In particular, official factory servicing states that the neoprene gasket between the case and caseback of the watch should be replaced every time that you change the battery. In fact, most people, including me, re-use that gasket if it still looks pretty good when I open the watch. That definitely compromises the factory water resistance rating.
Bottom line: If you have a watch rated for 10 ATM of water resistance that's a few years old, I wouldn't be all that concerned about getting it casually wet, or even going swimming with the watch (I'm paranoid enough that I wouldn't do this, but I'm probably in the minority). However, I wouldn't go diving with a watch that's had its battery replaced unless it was re-tested for water resistance after the battery was serviced. Some but not all jewelers have special machines that perform this test. If you're interested, you could probably pay one of them a few dollars to have your watch tested. They don't have to do anything to the watch other than place it in their machine, so it's not a big deal for someone who has the equipment to perform this test.
May 20, 2011 | Watches
Is my bulova watch water proof?
If you look at your front dial you should see 30m, 60m, or 100m, if you see one of these numbers it is water proof, so for example 100 meters = 330 feet.
Apr 03, 2011 | Bulova Watches
How water proof can you dive to with them?
Only if the water resistance is 100m or more.
If your watch has a "no water" icon, then it should not be allow to get wet.
Sep 21, 2010 | Nixon Rotolog Leather Watch
Can I swim laps w/ my ebel 30 meter watch? The watch has 4 screws on the back and the crown does not screw down.
Thank you for contacting FixYa.
Water Resistant is a common mark stamped on the back of wrist watches to indicate how well a watch is sealed against ingress of water. It is usually accompanied by an indication of the static test pressure that a sample of newly manufactured watches was exposed to in a leakage test. The test pressure can be indicated either directly in bars, or (more commonly) as an equivalent water depth in meters (in the United States sometimes also in feet).
An indication of the test pressure in terms of water depth does not mean a water resistant watch was designed for repeated long term use in such water depths. For example, a water resistant watch marked at 30 meters depth cannot be expected to withstand activity for longer time periods in a swimming pool, let alone continue to function at 30 meters under water. This is because the test is conducted only once using static pressure on some of the newly manufactured watches. The test for qualifying a diving watch for repeated usage in a given depth includes safety margins to take factors in account like aging of the seals, rapidly changing water pressure and temperature, as well as dynamic mechanical stresses encountered by a watch. Also every diving watch has to be fully tested for water resistance.
Hope this helps.
Jewel
Sep 02, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
Looking for user guide for model 4511 Desert Falcon Zodiac watch
Clearly a screwdown crown is better for water resistance but most watches maintain a seal without it. I wouldn't test out the 100m claim but it should be safe in the pool.
Apr 29, 2010 | Watches
F-117 Nighthawk 6402 series, moisture has entered watch face after swimming in pool on holiday.
This watch is resistant to 200m so shouldn't allow water in at swimming pool depths.
It looks as though one of the seals has failed.
If it still under warranty (less than 2 years old), then contact your nearest authorized dealer
To find your nearest dealer or their service center, go to Luminox.com. At the top of th epage you will see a list of links.
Feb 23, 2010 | Luminox Evo F 117 Nighthawk 6402 Watch
I was swimming in ocean. Somehow, stem opened and
the hair dryer didnt do any damage but the water might have destroyed the movement, some ar inexpensive, get an est. to replace it. make sure u go to a good jewelry store.
Oct 09, 2009 | Navy Seal Luminox Watch
Guess Steel Water resistant is not water resistant!!!
Water resistant does not mean water proof. You should never wear this watch while bathing, swimming or in sauna.
Any watchmaker will be able to remove any condensation and dry out your watch - no matter you are in the U.S.A. or Romania.
Find your nearest watch repair shop and ask for help.
Rate, please.
Jul 20, 2009 | Guess G66355L Wrist Watch
My Polar F6 is not water resistant like it's supposed to be??????
Your watch is water resistant...not water proof...which means if you get a little water on it, fine..but certainly not wearing it in the pool!
Jun 28, 2009 | Polar F6 Wrist Watch
Watches Logo
24 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
