Question about Dell Inspiron 531S (DDCWGA1_5) PC Desktop
I have an Dell inspiron 1525, I recently updated either my windows or my windows secerity program (can't remember) anyways it told me to restat my pc. So I did i'm guessing it was never done down loading the updates and I shut it off before it was done...now my laptop acts like it wants to start up it comes on saying DELL and even goes to the screen with the blue loading lines at the bottom after that it says "start windows normaly" or "recomended scAn" either one I click it goes into a scan screen (it's a black screen white lettering) it starts scaning then always says "autochk program not found - skipping AUTOCHECK !! 0xc0190036 !! 777 / 46586 (TCPSVCS.EXE)" i shut it done a few times and every time the scan stops at 777 Is there any way you can help me please! I just want my laptop to turn on again it's only a yr old. Thank you, Cathy
    Brigadier General:
  • 8,909 Answers
It sounds like it is confused and has lost some of the registry entries, like we would have an index to find the files. Hopefully they are all still there.
Press F8 as it boots up, this should get you into a sub menu that allows you to use Safe Mode or Recovery. Try safe mode first as Windows will search for the "missing" files and repair the registry. If that doesn't work try Recover and follow the prompts. (That may only work under F11).
Hope that fixes it.
Posted on Dec 30, 2010
I run Dell Inspiron 1525 , it boots well , but can't open any windows program,
Hello.
You probably have an operating system problem with corrupted files.
Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
May 09, 2011 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 shuts down
You have had Win 7 for TWO YEARS? Hmmmm well anyway thats the problem. You see Win 7 and games don't MIX, the only way may help is to run in compatibility mode for XP SP2, and Run & Install as Administrator.
Mar 19, 2010 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 laptop shutdown problem
The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
This will help the Software and Hardware to communicate with each other...
Jan 01, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
Integrated webcam fail 1525
its a common problem with 1525. remove webcam ventral software from programs and features and then reinstall the application from the cd. it will fix it. remember Dell web cam central
Sep 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Windows Vista Blue Screen Error
Try this...on boot up hit F8 and select SAFE MODE and see if you can get in that way. Look on the control panel for add and remove programs...eliminate Uniblue from the program list. Reboot and you just may be fortunate.
Isn't it funny that the program that is messing up your machine is the one (for money) will fix it.
I still think the best way to update drivers is right from the manufacturer (ATI , nVidia, ASUS,)or the computer company (Dell-Gateway-HP) they all have driver updates for FREE in their Support area look for Drivers and Downloads. To contact their sites try the Company name and .com
I also think if things are running along just fine...don't update until performance suffers. Like your daddy told you...if it ain't busted, don't fix it.
hope this helps...good luck my friend
Dec 27, 2008 | Dell Inspiron 1525 Laptop
Dell Inspiron 531S (DDCWGA1_5) PC Desktop Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
