Question about Bruder Cat Skid Steer Loader
I have an 863 bobcat that doesn't idle well and continues to quit running. I changed the fuel filter, put heat in tank and a little bit of diesel conditioner anti-gel.
    Sergeant:
  • 223 Answers
There should be more than just one filter on that motor, check at the lift pump and injector pump.
Gelled fuel can be a pain, if that's the problem then warm it up (tarp and salamander for a few hours or leave it inside the shop overnight if the shop is warm), top off the fuel and give it a can of Power Service brand Diesel Kleen, then try it.
lp
Posted on Dec 30, 2010
  • alexandra180 Dec 30, 2010
    Thank you Guru I will try that first.
    Alexandra
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
Had some gas in a can, so i poured maybe a gallon of it in my tank to make it to station. then found out it was diesel fuel. i only drove it a block and noticed it tryin 2 boggle out on me so i parked it....
Diesel should not hurt your car as long as you did not put to much in your tank. I would recommend that you buy a good bottle of octane booster dump it in your tank then fill it up with a high octane full like 91 octane. That should make up for the difference. Your car may smoke a little bit until all of the diesel is out of your system but it should be fine after that. I hope this helps and if you have any other questions please feel free to ask.
Sep 19, 2011 | 2002 Dodge Intrepid
Had about 4 gal of diesel in tank and someone put 5 galons of gas in tank. Drove a mile and stopped for not sure how long. Went back out to start and would not start.
it all depends on how much diesel remained in the tank before the gasoline was added, and how new and sophisticated the diesel engine is. In a 2007 or newer clean diesel engine, any amount of gasoline will probably damage the sensitive emissions control components (DPF, OxyCat and SCR) and system. In older engines with much less sophisticated and "touchy" emissions systems, a lightly diluted (say 90 percent diesel/10 percent gasoline) mix would probably pass through with little or no detriment. It might simply cause reduced engine power, perhaps a bit more noise, and possibly a sharp warning from the emissions sensors that detect something other than pure diesel exhaust. It's high concentrations of gasoline that spell real trouble. Whether a modern clean CRD diesel or an old indirect injection unit, burning straight gasoline or highly diluted diesel fuel will almost certainly result in catastrophic damage to the mighty diesel engine.
May 12, 2011 | 2005 Jeep Liberty
I accidentaly put diesel fuel into my 2000 Acura 3.5 RL, the tank is 18 gallons, it was at about 2 gallons when I filled the tank with 4 gallons of diesel, I got the car towed back to my house, what steps,...
Very easy! Get a siphon and get all of the fuel out through the fill hole. Then put 5-10 gallons of good fuel with a can of Seafoam this will help to dilute any remaining diesel that is left. Start and let idle for at least 10 minutes. It may run rough for a little bit but will clear up and you will be ok! Good Luck!
May 11, 2011 | 2000 Acura 3.5RL
Replace fuel line on 863 bobcat
you need to take off thr right rear tire and remove inspection plate,then reach in and pull line from top of tank. if pickup tube is original eqip. it has probably broke off. you will find 3/4 of old tube in bottom of tank. go to bobcat dealer and get replacement tube,which is now all poly and flexible. while you are at it,reroute fuel line to the plunger,by putting it down bottom right side of engine,right under motor mount below alternator. an easy test of fuel line is to take off fuel cap and then blow air in hose at primer bulb towards tank.if you hear the air at fuel tank opening,your tube is broken. if you hear bubbling line should be good. you need to have a can of air in your tool kit,go to walmart and get can of air in the electronics department,the opening is small,get yourself an male air fitting from automotives and put on end of air can,use pipe tape on end. if fuel line gets dirty you can blow back to tank at primer bulb,this an emergency fix,if primer bulb is collapsed the line is clogged or pickup is clogged.
Jan 11, 2010 | Bruder Cat Skid Steer Loader
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
Oct 31, 2009 | 2004 Ford Fusion
What do you have to remove to get to the fuel tank on 863 bobcat
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Diesel in gas in a 2008 Yaris
I would recommend draining the tank, replacing the fuel filter, you will probably have to replace the spark pugs as well. You may want to also blow out the fuel lines if easily accessible. Put in new gasoline, a fuel system additive, and run it for a little bit (may get some smoke for a bit, and my be hard to start at first and run rough). Hope this helps.
Mar 13, 2009 | 2008 Toyota Yaris Sedan
Bruder Cat Skid Steer Loader Logo
718 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
