I want to Tune my Conia tv, so I get the HD digital channels like 99 - GO and channel 72
SOURCE: TV not finding Digital Channels from Cable Box
I just bought Sony LCD 46 inches, with model KDL 46 V 2500 about less than 9 months,now TV lost digital channels, I tried every thing to program it but it's not working, when I program it the screen come up and stay about 20 minutes for searching digital channels then disappeared.and always no digital found.I don't know what wrong?
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 87 Answers
SOURCE: QAM Tuner difference between Toshiba & Samsung
software upgrade available from toshiba.
Posted on Apr 24, 2009
SOURCE: Cannot find freeview/digital on our new TV
problem as above please help
Posted on Sep 10, 2009
How to tune samsung tv
Mono is the first point I am stuck on. Mono is an audio reference but I am going to assume that you are only receiving the analog channels and not the digital. If you are coming off of an antenna then the antenna has to be HD to receive HD channels over the air. If you are off of a cable box then this has to be dealt with from your provider. You will also need an HD ready TV or if you do not you will need an HD converter box to make your tv work with the digital signal.
Apr 02, 2014 | Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
How to tune channels on conia tv
Yes, but it only processed analog channel, the digital one could not find any. It is very strange!
May 13, 2012 | Televison & Video
Missing HD Channels on Sony Trinitron KV-DA32
You may have to select off air or outside antenna from the set up menu. This is what I do with mine to receive digital over the air signals....
Feb 06, 2012 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
How do you tune in to get freeview HD on the TXP42S21B
You simply need to perform the auto-setup when you first use the television. The freeview HD channels will tune in at the same time as the standard def. (SD) channels. You will find them in your channel list but there are only 3 freeview HD channels currently available - BBC HD (Channel 50), ITV1 HD (Channel 51) and Channel 4 HD (Channel 52).
If these channels are missing, it's may be because the HD broadcasts haven't started in your area yet. Please visit this page and enter your postcode to find out if you can get these channels:
http://www.freeview.co.uk/availability/
If you've gone past the auto-setup and you need information on how to tune your TV, please consult your manual or post back here and I will assist you.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | Panasonic Televison & Video
ON CHANNEL SELECT WE HAVE TO PUSH 3 NUMBERS IN ON REMOTE CONTROL INSTEAD OF 2. EX. CHANNEL 72 MUST BE PUSHED IN AS 72-1. IS THERE ANY WAY TO CORRECT THIS PROBLEM ON THE REMOTE CONTROL SO WE DO NOT HAVE...
Sounds like you need to do a channel scan. This would be found under the Menu and then channel setup. If there is an option for scanning for digital or analog channels, just scan for analog. Channels with a dash are usually a digital station. If you really want to get digital or HD channels, I would recommend getting the HD box from your cable company and use the HDMI or Component connections.
Oct 18, 2010 | Vizio VF551XVT 55 in. HDTV
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
No signal on digital TV
Apr 26, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
