Question about HP Photosmart C6180 All-In-One InkJet Printer
Says Ink system failure
Gives error code 0xc18a0201
  • 1 more comment
  • sportcolbs Jul 09, 2008
    Thanks for the suggestion, but it did not work
  • sportcolbs Jul 10, 2008
    I hit the * key then # key and went to diagnostics by hitting the > key by the OK button. That seemed to clear the problem. I then turned the printer off, unplugged it for about 5 minutes and turned it back on with no cartridges which it then requested. Upon inserting the cartridges, it showed ink levels. I went to clean mode and then the printer worked!!
  • Anonymous Mar 19, 2014
    whem it start it give the msg
    Novelist:
  • 106 Answers
Here are the steps that i want you to follow exactly to resolve your isse.
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. Thank you so much. adonscott
Posted on Jul 09, 2008
bandana_gyrl
  • 181 Answers
SOURCE: I have a printer ?HP c7280 All-in-one?a message,
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: ink system failure
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
  • 28 Answers
SOURCE: HP C7280
Check out this Thread about Ink system failure.
Ink System Failure Forums <--- Click here
Posted on Mar 08, 2010
nonontech
  • 4737 Answers
SOURCE: Ink system failure
Try the following tricks:
Press and hold the “left arrow” key.
Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release the “Ok” button Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “Ok” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear.
Press Ok to clear”.
Press and release the “Ok” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “Cancel” button as many times as necessary, so that, either the “Welcome to
Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.Please do not try to Print at this stage.
Using the Power Button, turn the unit Off and unplug the power cable from back of the printer and wall outlet.
Turn the unit on. The printer may display message “Use only the power button to shut down the printer” followed
by “Press Ok to continue”. Press Ok. If the printer has already initialized, then go to the next step. If not, the printer will start the
“One time ink initialization process”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a Self Test Page. If Self Test prints, then printer is ready for use.
Good luck, Thanks for using FixYa.
Posted on Jun 03, 2010
  • 67 Answers
SOURCE: Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Posted on Jul 29, 2010
I have an HP printer c6180 and am getting error 0xc18a0201
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Dec 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have an error message on my HP Photosmart C5180 All-in-One printer stating: Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0201
Hi!
Ink System Failed is displayed becuase the printer head can not communicate with the main board of the printer and this can happen due to print head failure there is nothing you can do except repairing the printer.
Aug 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C7280
Hi there It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | HP Photosmart C7280 Laser Printer
Hp c5180 printer: While printing a job, the
it sounds like the printer is malufunctioning...it might be a problem with the printer head..see where the printer opens for the ink.. look at the yellow space for the ink.. remove the ink and take a cotton swab full of alcohol and clean it then let it dry and place the new ink cartridge there and restart the machine..see if it gives the same eror..if it does consider replacing the device
Jul 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart printer Ink System Failure Error 0xc18a0201 happens every time I start it.
You press the button to turn off the printer.
Unplug the power cord from the back of the printer. Unplug the power cord from the back of the printer.
Remove all the ink cartridges. Remove all the ink cartridges.
Wait two minutes. Wait two minutes.
Plug the power cord into the back of the printer. Plug the power cord into the back of the printer.
Press the On button to turn the printer on. You press the button to turn the printer on.
Install the ink cartridges when prompted. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error code does not display, the issue is resolved.
Dec 05, 2008 | Computers & Internet
Ink supply system failure on a d610 hp printer
hey I have a hp photosmart 8250 inkjet printer problem i need to know if I can fix from home myself are do i need to take it to a shop Error code: 0xc18a0201
Apr 25, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
777 people viewed this question
Ben Johnson
