Question about Microsoft Xbox 360 Console
C000022d and unpluging and replugging in the cord hasnt worked, also i have done all updates
Its Microsft...by scamming poor people is how they get rich!
Posted on Jan 17, 2011
43code error
(Laptop) unplug the power cord, then take out the battery, unplug all usb devices, leave it alone for a minute or two and then replug the power cord and then the battery. Turn the computer on and restart as normal. replug in your usb devices and they will reinstall as usual
Sep 30, 2013 | Electronics - Others
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
My printer will not turn on it worked yesterday and i've done nothing different. could it be the "brick"?
Try to unplug the power adapter from the printer.
Check if it's warm or cold. It could be a defective power adapter issue. Unplug and replug the power cord into the power outlet to reset it. Bypass any surge devices or power strips. Replug the power adapter into the printer. The printer should automatically turn on, otherwise press Power button.
If problem continues, then it could be a faulty power adapter problem. I'd suggest you to contact Lexmark technical support for additional assistance.
May 17, 2011 | Lexmark X2500 All-In-One Printer
Can't get online
Try power cycling the router:
1. unplug the power cord from the router
2. unplug the power cord from the modem
3. replug the power cord to the modem
4. replug the power cord to the router
for best results, wait approx. 30 seconds before re powering the devices.
Mar 03, 2011 | Computers & Internet
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
Wireless connectivity suddenly lost
Have you tried power cycling the router and the modem? if not:
1. Turn off your modem and router by unplugging the power cord at the back of the devices.
2. Disconnect the Ethernet cable from the modem to the router vice versa
3. After a minute, replug the power cord at the back of your modem then reconnect the ethernet cable at the back of the modem as well.
4. After a minute, replug the power cord and the ethernet cable at the back of your router.
5. Try to test the connection.
Warning: You can reset the router if you know that you can reconfigure it back to connect to the internet. If you don't know how to set the router back to connect to the internet, it would be ok to you to not to do step 6.
6. If it didn't work, You can reset the modem. Press the reset button at the back of your router while it's turned on, wait for 15 seconds after that, unplug the power cord at the back of the router while the reset button is still pressed, wait for 15 seconds after that, replug the power cord at the back of your router while the reset button is still pressed, wait for 15 seconds again then release the reset button after 15 seconds.
7. Reconfigure your router's settings to communicate to your modem. ( I don't know if you have cable internet connection, but if so, you can just clone the mac address of your modem to connect to the server, if you are using DSL if it's asking for a username and passowrd, just use the PPPoE type of configuration in your router)
8. If it failed, try to update the firmware of your router.
Jan 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Printer not commincating with the computer
First, try to unplug and replug the usb cord. If that doesn't work, uninstall and reinstall the printer software. If that fails, go into the control panel and update the driver software.
Oct 22, 2009 | Office Equipment & Supplies
K can you help me, my mouse just stopped working. it hasnt done anythign since ive got home its on the thing is pluged in but nohting is happning
I have problems with my USB mouse sometimes too.
First, I unplug and replug the cable from the computer. Sometimes, the computer puts the USB port to sleep to save power when you aren't using it, and windows isn't always good about waking it back up.
Next, try restarting. This can help with a lot of things, just to get a fresh start.
If that doesn't work, try the drivers.
Oct 11, 2009 | Targus PAWM001U Mouse
Power problems
have you tried unplugging and replugging in cord and waiting 3 minutes? Otherwise you have to go to control panel, then go to power settings and check to make sure it is enabled
Jul 07, 2009 | Dell Inspiron 1521 Laptop
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Microsoft Xbox 360 Console Logo
204 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
