Question about Sony PlayStation Portable (PSP) Console
PSP Directional Pad does not work
My son has had his PSP for some time....and the directional pad is loose and does not respond consistently. Can that be fixed?
  • 97 Answers
Sell it. thats a mother board problem it costs 110 buvks to fix. ill buy the psp
gabrielsimut@yahoo.com
Posted on Jul 08, 2008
PSP directional button going crazy but button is not stuck
the analog button contact pad maybe loose or the body fixing screw maybe loose.
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Down arrow key not working properply; cursor keeps moving up on its own: sometimes doesn't respond to down arrow key being pressed
u probably have sticky stuff and dirt in the directional pad, try this:
take the battery out, make sure the power is off, pour a little alcohol in the the crack of the directional pad, then press the directional pad in the different directions to loosen it up, finally let the psp sit for a few hours til the alcohol dries (or blow in it) that sould loosen everything up, if that does not work you will have to open the unit and clean the pad thorougly...
Jul 13, 2009 | Sony PlayStation Portable (PSP) Console
Directional buttons work fine, until I start playing a game
Ok. navigate to system settings and scroll down to RESTORE SYSTEM SETTINGS, after that turn off your psp and wait for about 3 minutes and turn it back on.
Write back if this doesn't help.
Apr 18, 2009 | Sony PSP (Piano Black)
Directional buttons
its dirt man.. take your console back to where you bought it so that they can check. There are no other reason why your d-pad wont work.
Feb 01, 2009 | Sony PlayStation Portable (PSP) Slim...
Directional buttons for PSP not working.
Star wars: force unleashed was a bad game... anyways:
Maybe the disk isnt read rite by your psp. maybe the disk is wrong?
Or it could just be that you dont use the directional buttons for gameplay, just the analog stick. XD
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
Directional pads not working
the new one have a problem with bracking send it to the people who made it
May 19, 2008 | Sony PlayStation Portable (PSP) Console
My PSP the new version
do you mean the four buttons or the joystick? If it's the joystick it could be the piece of jelly/plastic that connects it to the motherboard
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Jan 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
PSP unresponsive
Hi Flying back,
I think your PSP may have had a confrontation with moisture. It sounds like the D-pad has one of the circuit pads shorte together full time. If one of the direction pads is always on, it will ignore the rest or add to them for a diagonal move. You need to open up your PSP and Look closely at the circuit pads for a form of short circuit across from one side to the other. you can scratch the short away if you find one. This should help. Good luck.
Dec 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
162 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
