Question about Toshiba Computers & Internet
Hello there Please could you help ? I have been experiencing intermittent USB problems recently, to the extent whereby I have certain devices which are operable, i.e. external HD, PDA, external speakers, although certain devices such as wireless receiver for mouse/keyboard (which once did work) head-phones and now even my i-phone do not operate, although device manager sees them, they are shown with yellow exclamation with Code 1 ??? I have attempted to re-install new driver (Intel Chipset) as well as running registery cleaner etc. Is there anyway of reapplying USB 2.0 EHCI driver to try and fiz this problem as much web research has so far proved fruitless ? Yours in anticipation Tommy
  • Anonymous Dec 30, 2010
    Thanks so much for coming back to me.
    Have just run the BIOS update from http://uk.computers.toshiba-europe.com/i...
    Brigadier General:
  • 8,909 Answers
Contact Toshiba.com and download fresh BIOS firmware and drivers that are more up to date. It is realy easy to do once you connect to Toshiba.
This will sort your problem out and update your laptop,
Posted on Dec 30, 2010
  • specialistel Dec 30, 2010
    I am pleased to help as I have a Toshiba L300 and had similar problems, the toshiba web site sorted out all of my problems and it flies like a nes laptop now.
    Kindest regards and good luck.
    thanks specialistel, the BIOS update did not do the trick unfortunately. I am in the process of reapplying chipset update, as well as firmware. am at a bit of a loss and have done much research into this problem. are you aware of USB issues associated with the Toshiba LT (I have a A300) ?
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Mike
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
My pendrive not pick up by my system and not
You need to certain things.
  • If your pen drive is not being picked by any system, it is vital to see what the error message it gives.
  • If it says: USB device not recognized there is nothing more you can do. It means that the device driver installed in the pen drive is either missing or is corrupt or even was not installed (if you purchased it recently). What you can do is to get it replaced from your retailer.
If it says something else, please inform me, I will be following up your problem.
We are always there to help you out.
Regards.
Jul 21, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Experiencing various electrical problems
The most common cause of intermittent problems is a poor ground connection.Check the engine and the chassis grounds for tightness and clean surfaces.
Oct 31, 2009 | 1994 Volvo 940
Sony Walkman NWZ-A826 will not conect to laptop via usb cable
I experienced exactly the same problem on my laptop (Vista Home Premium) after upgrading to NIS 2009.
From Control Panel, I went to Device Manager. Under Portable Devices there was a yellow exclamation mark aginst my walkman (Micosoft Code 19 error). I read around a bit before deciding to click Uninstall. Once that was complete, I clicked on Scan for hardware changes, and hey presto my walkman was recognised again.
This is almost certainly connected with NIS 2009 installation as my walkman was recognised by another laptop (XP) which is NIS 2009-free.
Jun 03, 2009 | Sony Network Walkman NW-E005 MP3 Player
USB Ports won't work
Please enter CMOS setup and verify that the USB port is enabled.
Nov 25, 2008 | Toshiba Satellite A105-S2001 Notebook
Insufficient power at high revs
Hello, if you have a bad reed valve buy a new one! Sometimes u can flip a reed valve over, but it will be a short fix. I hope this helps
Nov 23, 2008 | 2001 Suzuki AX 100
Changing a display name
it depends on the phone system type. The name changes are done in programming mode. But to enter programming varies by system. You need tech support.
Nov 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
Craked mp3 screen.
Hello paulgilby,
Cracked LCD screens are one of the most common problems experienced with MP3 players. Unfortunately such a failure is considered to be physical damage and is generally not covered by any warranty on the unit.
If you have experience repairing electronics devices you may be able to repair the device yourself. Parts are typically available from the manufacturer. The manufacturer may be able to offer repair services for you as well. However, depending on the extent of the damage it may make more economic sense to simply replace the unt.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | Audio Players & Recorders
Hand-set Intermittant and clicking
If all your handsets simultaneously recently starting having this problem, the first start would be replacing your base after you have determined a site problem as cropped up. Did you or a neighbor add any wireless devices lately? Did you move your base? Your problem is a common problem with all cordless devices where the base and handsets are not communicating properly with eachother, it is common that it is interference, or your radio modules in your base/handsets are failing. Try powering down you base for a while, then give it a try. But I would look at your environment and see if anything changed. Good Luck
Mar 30, 2008 | Siemens Gigaset 2420 Cordless Phone
Computers & Internet Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
