Question about Coleman Heating & Cooling
Water line under spa froze and broke need new parts
    Problem Solver:
  • 11 Answers
Yeah Sooooooooooo???????????????
Posted on Jul 08, 2008
Icemaker issues
If your ice maker still in guarantee or warranty period, then go to the seller and replace with a new one. If not then go to google and type in ice maker repairer in your area and you will find plenty of website of repairer.
Mar 15, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
I just installed a 2 hp AO Smith for a customer, 2 days days later one of the return lines broke and sprayed water everywhere. When I got there and fixed the line and tried to start the motor it would only...
You should try to dry the motor out and not run it until it does. You can use a hair dryer, etc. or just wait. You might even be able to find a spray that is made just for absorbing water under these circumstances at a motor rebuilder. Once it dries, it may work fine.
Dec 15, 2010 | AO Smith 2hp Pool Pump Motor Ao Smith...
New unit never used found the water filter cracked
Apr 24, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Windscreen washers weren't working. connection to the jets had come undone.(probably due to frozen water in the pipe) tried to reconnect and one plastic pipe broke close to the connection.(about 2,1/2...
if i understand what you are saying correctly, the line leading to the nozzles in the hood broke, not the nozzles themselves. if the line broke in the middle somewhere, you can go to the auto parts store and buy a piece of rubber vacuum line, just slightly larger than the plastic line and use the rubber line as a splice. has to be a very tight fit or the rubber will leak or blow off when under pressure. if you have a set of measuring calipers, you can measure the plastic line, or just cut off a very small section and take it with you.
Feb 21, 2010 | 2001 BMW 5 Series
Heeeelp! How to hook up hoses on Sundance spa
There is a skimmer in the side of your tub( the part that skimms water off the top ) and what is called a main drain or a better tearm is deep suction that pulls water from the bottom of the tub and helps collect heavy dirt from in the tub these two lines ( three if there is more than one main drain) These will all come together and then hook to the front of the pump. If your filter is under the skimmer basket the top of the pump will go to the heater and then back to the spa. If your filter in not under the skimmre basket then it will come after the pump then on to the heater. So in answer to your second question, the front of the pump draws the water in and the top pushes the water out. But make sure that your heater is last in line so it only deals with clean water and it will not run on the suction side of the pump as it need water pressure in it to start and contious flow to keep it from over heating. Hope this helps.
Sep 25, 2009 | Pool & Spa
I have gilmour 9400 water timers ,some froze,need parts
I have the same problem. Mine blew out the O ring and it pops back out when under pressure. I just need the black back part, the electronics are fine.
Jun 04, 2009 | Garden
Frozen, broken kenmore fridge water filter
Hello Leslie176,
They are called reverse twist bolt/screw extractors..
The prettiest I have ever seen came from EASTMAN restoration products..
You are looking for the variable sized set that fits into an ordinary soct wrench with... EXTENSION (should get you into the filter housing...
You will hhave to replace the whole Filter housing
IRWIN HANSON Hex Head Multi Spline Screw Extractor Set 25 Piece 53227 Hex...
Check out the eBAY version
(you don't need QUALITY STUFF for plastic
Hanson AHN53204 7 32 034 Hex Head Multi Spline Screw Extractor Bulk NEW...
Apr 13, 2017 | Frigidaire FRS3R5EMB Side by Side...
Heating & Cooling Logo
21 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
