Question about Dryers
Crosley Gas Dryer
Model # CGDS774JQ0 will run but will not heat up. I have removed the igniter and the Thermal from the side of the burner. Also the Hi Limit in the back of the burner along with something else (Looks like the Hi Limit only bigger with 4 plugs) from the vent. What type of readings should I get from these and what else could be the problem
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Here are some things to look for:
Click on the red underlined links for information on that part.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • David Emmel
    David Emmel Jul 09, 2008
    The red underlined links appear to be blue after posting.
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Dryer stopped heating how do you light the pilot
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.
Mar 14, 2011 | Crosley Dryers
Dryer will not heat
Check the reset inside the dryer. You will need to open the machine. The part looks like this one. If this is ok, then check the heater element for continuity with a multimeter. If you need the heater element, here is a link to the part.
Dec 26, 2010 | Fisher and Paykel SMARTLOAD DE62T27G Gas...
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
Crosley dryer fuses where r they
The thermal limit is located on the right hand side of the heater chamber. The dryer will not run if it is open. SOME REPAIR PHOTOS
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Kenmore 72062 Gas Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
You may have a bad heating element,unplug the dryer. you need a 1/4 in socket driver to take off the back panel this will give you access to the guts.If your handy you can buy a new one and replace it.Tell me if you need more help.
Hope this helped.Let me know by rating me.
For more help go to live chat.
lenwest
Jan 29, 2009 | Whirlpool TGDX640P Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
