Question about Electrolux Lux 5500 Canister Vacuum
Electrolux Super J model, bag light stays on and vacuum will not run.
  • 694 Answers
Have you checked the screen filter below the bag? This sometimes gets clogged with fuzz and whatnot, resulting in the vacuum shutting off. To clean it simply remove the bag and use a pick or similar item.
A clogged hose will also result in the same problem. Try running without the hose. If the vacuum runs without the hose a blockage in the hose is a probability. However there could be a clog in the power nozzle above the brush, as well. Check the suction at the end of the hose. If very little there's a good possibility this is the problem. Double check by dropping coin in one end and allowing to drop through. If it doesn't there's a clog. It can usually be cleared by plugging the hose into the exhaust port and turning the machine on. Be sure the other end is inside a large plastic bag.
Visually check wands to ensure they're clear. If not, push clog out with a broom stick.
Posted on Jan 16, 2011
My electrolux vacuum cleaner?
Sometimes the bag isn't installed properly.
Try removing the bag and replace with a new one making sure that the bag is in the bag compartment squarely on all four corners thus covering the bag door switch. Close lid and try again.
Hope that helps!
Mar 14, 2015 | Electrolux Vacuums
Electrolux vacuum cannister bag is not full, but vacuum will not stay on.
How long does it run when you plug it in....or does the on and off switch not work?
Jul 27, 2011 | Electrolux Guardian Bagged Canister Vacuum
I have an older model Electrolux canister vacuum and it turns off quickly after turning on and this checkered light comes on. It happened right after i finished cleaning the ashes in my stove which i...
Make sure there is no obstruction anywhere along the hose. Also properly clean the filter and collection bag. This may have become blocked due to the fine ash, sort of sealing the bag.
Jan 02, 2018 | Electrolux Guardian Bagged Canister Vacuum
I replaced the bag full, but the bag full light stays on.
This is most likely due to a broken, worn, or clogged control valve assembly (CVA). You can try resetting the dial to the smallest dot, but I'm not sure that will work for you.
Detach hose from vacuum. Turn vacuum on. If it runs, place palm over intake port. If it shuts off, then it's the CVA. This is a shop repair and should only be done by an authorized Aerus Electrolux service tech. It may seem spendy, but they can also do a clean and service to remove any dust in the interior of the machine and motor. This will extend the life of your machine if there's much dust in it.
The cause of this problem is often due to using "made to fit" Electrolux bags rather than the genuine bags. Genuine bags will always have "Home Solutions" printed on top.
For the nearest Aerus Electrolux store see below site.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux Epic 6500 Vacuum
Aerus Model 152C- vacuum doesn't run
it probably does think you have a full bag.make sure you have it cleaned out and has a bag in there or it might be the sensor for the vacuum and is not working properly. contact your nearest electrolux vac store.or you are not using proper bags.
Jun 28, 2009 | Electrolux Vacuums
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Canister - Renaissance model
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 5500 Canister Vacuum Logo
169 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
