Question about NEC (MTLAMP8101000) Projector Lamp for MT 810, 100
I need to reset the lamp timer after replacing the lamp. Red status light.
  • 76 Answers
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual. (It could have been the on button, can't remember now)
Good luck
Posted on Aug 05, 2011
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Lamp replacement
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
May 21, 2008 | Sharp XR-11XC Multimedia Projector
NEC (MTLAMP8101000) Projector Lamp for MT 810, 100 Logo
167 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
