My vcr will only record the channel I am on. When I try to set programming for another channel it will not record unless I am on that particular channel.
    Brigadier General:
  • 8,909 Answers
The vcr will only record what it is given to record. If your TV is the recording source, it has to have dual tuners to allow recording of one channel and viewing of another, as does the vcr.
Hope that clarifies the situation.
Posted on Dec 30, 2010
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Feb 09, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
