Question about NRS Stex 8025T Treadmill
Treadmill stops in the middle of my run. Error 2 is all I know. It promptly starts working again, then repeats the process again, usually after about 5-8 minutes.
Trimline treadmill repair e1
please LUBE the deck belt with silicone inmediately.
God bless you
Jun 04, 2013 | Exercise & Fitness
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    How to reset treadmill T630
    Dear Sir:
    I will try to help you.
      • 1
      • 2
      • 3
      • 4
      • 5
    If you need further assistance, please reach me, sincerely.
    God bless you.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Oct 24, 2011 | Exercise & Fitness
    Unlock the code on Precor treadmill?
    Dear Sir:
    Please try with this Reset system for Code:
      • 1
      • 2
      • 3
      • 4
      • 5
    If you need further assistance, please reach me. sincerely. God bless you.
    E.CUADRA
    Oct 23, 2011 | Exercise & Fitness
    My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
    From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
    1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    2.Press the "ENTER" button three times to access the treadmill's error log.
    3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
    I hope you find it very helpful.
    Sep 04, 2011 | Exercise & Fitness
    Kettler atlantis 51L error!!!! what is the solutions?
    I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
    Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
    Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
    Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
    Aug 17, 2011 | Exercise & Fitness
    E6 error - incline not responding. Replaced 1A fuse but still not working
    I'm getting the same E-6 error while running in program mode although the fuse is fine - and when I recycle power, the program starts fine again and then stops in the middle with the E-6 error. Nor sure what's wrong. Just sandpapered the fuse ends and the connector ends to the fuse socket. We'll see how it goes.
    Dec 14, 2010 | Sportsart 6300 Treadmill
    Can walk on treadmill but soon as i start to run it stops
    Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
    May 20, 2010 | Reebok Vista Treadmill - RBTL13305
    Machine won't boot to win xp
    You have two choices:
    1) Insert your e-machine system disk and boot from it. It should ask you if you want to install Windows or repair it. Choose R for repair. Then when you get the black screen with white writing, choose your windows installation (usually #1) and then press enter when prompted for a password. When you get the c: prompt, type chkdsk /r
    This might fix it.
    If not, then try the process again and don't choose "r" but continue through the screen when it asks you to accept the Microsoft agreement by pressing F8. Then on the next screen choose to repair the existing version of Windows. It will reinstall the system files and may actually fix your problem.
    Feb 19, 2009 | eMachines T3406 PC Desktop
    NRS Stex 8025T Treadmill Logo
    35 people viewed this question
    Top NRS Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
