Question about Freezers
I have a E388 F&P Upright Freezer. A few weeks ago I noticed that that some of the meat was thawing. I thought the unit was on the way out, so I transferred the contents to another freezer and turned it off. A few days later I noticed the plastic container above the comnpressor was full of liquid, it was previously empty. I then turned the unit back on and it performed normally again. It froze new contents from room temp to solid in about 1/2 a day. I performed ok for about 2 weeks. It has now done the same thing again. I switched it off again and emptied it and the plastic container above the compressor filled again. One of my fridgy mates reakons there is a timer on the compressor to perform the frost free function and this is probably faulty because without it the evaperator will freeze solid and stop the cooling function after a while. It his likely to be the problem and can I get a wiring diagram to locate the timer? Any help appreciated.
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
Krazytech
  • 725 Answers
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
  • 161 Answers
SOURCE: Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Posted on Jun 30, 2008
  • 1462 Answers
SOURCE: servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Posted on Oct 18, 2008
tborn6
  • 700 Answers
SOURCE: kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Posted on Jan 12, 2009
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Amana Freezer not running
Take something and plug in wall socket to make sure you have power to the reciptical... somethng that new .. seems like you have ...NO power to it.. do u have a light in freezer and does it come on inside the freezer???
Sep 02, 2007 | Freezers
Freezers Logo
178 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
