Power adapter for western digital WD2500B011-RNN
I need a power adapter for the Western Digital WD2500B011-RNN External hard drive - can you help?
  • Anonymous Aug 30, 2008
    same here
Simply call up WD support line.
URL for all their support numbers are here.
http://support.wdc.com/contact/index.asp?wdc_lang=en
Have the serial number of your drive to hand and they'll send you a replacement powersupply out to an address you specify within 5 to 7 working days FREE OF CHARGE.
Cheers, Craig
Posted on Jun 16, 2009
Western Digital Hard Drive WD2500B015 getting power but will not turn on...Suggestions?
Buy a new external hd enclosure and reuse the hd from the failed enclosure. Hard drive enclosers are cheap BTW. Try newegg!
Dec 06, 2014 | Western Digital Computers & Internet
WHAT IS THE INPUT VOLTAGE AND AMPS OF A 500 GB WD EXTERNAL HARD DRIVE. I LOST MY ADAPTER
You can normally buy a replacement adapter from Western Digital from this link, but they are out of stock at the moment.
http://www.wdc.com/en/products/products.aspx?id=240
As an alternative place to purchase this, it looks like you can buy it on Amazon.com
http://www.amazon.com/GEP-Adapter-Western-Digital-External/dp/B004IG548U
Feb 26, 2011 | Western Digital My Book Essential Edition...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
Oct 28, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Western digital 500GB harddrive not switching on
Did You Try Using The Included AC Adapter To Power It Up
Jul 18, 2009 | Western Digital 500GB My Book World...
Computers & Internet Logo
6,707 people viewed this question
David Payne
David Payne
