Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
I have an Oster Golden A5 2 Speed animal clipper and don't know how to change the blades. I live in Australia so can't go to Oster. How do I do it please and is there a comprehensive Oster Manual? Thanks, Wendy
  • 193 Answers
Hi, if you look at the blade while its attatched to your clipper, at the back edge of the blade there is a black metal peice called a Latch push this towards the blade and pull the front edge away from the clipper it will hinge away then you can pull it straight off.
As for an instruction manual if you have no luck contact us and we can send one to you.
Posted on Jan 29, 2011
  • jsdogmom Jun 05, 2011
    I cannot get my Blade back on my Oster A5 clipper (single Speed)..what am I doing wrong?? They need to make these things much easier for people..Thanks
Oster problems. Golden a5 clipper
The blade driving lever is certainly supposed to move, if it isn't then take the cover off and check the cam gear, it's really easy to change it.
Jul 17, 2014 | Oster Golden A5 2-Speed Universal Motor...
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Mar 31, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
889 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
