Question about HP Tablets & eReaders
Windows cannot find any hard disk.This error comes whil i install window xp on my hp dv2001 laptop
  • 90 Answers
Shutdown your laptop. start it press f10 to enter bios. after getting into bios goto security then find sata native support .disable it try reinstalling windows.
Posted on Dec 30, 2010
Testimonial: "thanks buddy .my windows run fine now"
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
Feb 28, 2011 | Gateway M280E
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
How do I recover my administrator password?
Hi, man. Don’t worry, there are many people forget their admin password or lost it, and there is a popular solution for those who have been locked out by computer. For this solution, what you need is a second computer that can connect to Internet and then freely download Windows Password Recovery 6.0 at http://www.recoverlostpassword.com/products/windowspasswordrecoery.html With it, you can create a reset CD which can be used to reset Windows admin password without erasing anything.
Jan 05, 2010 | Toshiba Satellite R10 Tablet PC
Fresh vista install won't take and laptop acts all goofy
seems like a hardware problem...Hard Disk Probably.but don't take chances...first remove any external hardware attached [usb,printer etc.remove the battery also]then try to install the OS use another CD or you can even use Windows XP.Make sure you change the SATA setting in the BIOS for XP. You did not mention the error message or when does it hangs while installing Vista.Try changing the Hard Disk.If there's still problem then it's your motherboard. As far as overheating is concerned you need to see how long does it remain powered on.And when you switch it on again does it turns off quicker than before. Take it to the service center.
Aug 30, 2009 | Gateway C-141XL Notebook Tablet PC
O*oooooo7b(0*f7a21524,0*c0000034,0*00000000,0*00000000)
If you can install Windows Vista and only XP not work for sure this is the solution :
SATA operation mode is AHCI
To change this :
Open BIOS
Look for SATA Operation Mode or somethin equivalent and change-it to IDE or Compatibility Mode.
Jul 19, 2009 | Compaq tc4400 Tablet PC
Replace hard drive but can't load tablet operating system
Do you have the system restore disks for your tablet? Once you have restored windows then you need to use the second disk to load all the drivers
Mar 23, 2009 | Compaq tc4200 Tablet PC
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
155 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
