How to change the timer knob on the top loader washing machine
  • wathen Dec 30, 2010
    The model no is: kaw793w/3050
  • Washing Mach... Master
  • 19,396 Answers
Hi.
You usually have to open the top panel. After lifting the top panel you will see the control assembly. I can be more specific and I may be able to provide diagrams if you give me the full model number of your appliance, as printed in the service tag.
Regards.
Ginko.
Posted on Dec 30, 2010
  • Ginko
    Ginko Dec 30, 2010
    Hi.
    With Kleenmaid you do not need to lift the top panel. The control assembly is undone removing the screws , trims and caps holding the assembly. The screws may be hidden by trim strips. See the doagram below from similar Kleenmaid 651 :
4 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Posted on Jun 29, 2008
  • 343 Answers
SOURCE: kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Posted on Apr 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 plus machine, top loader. the machine
Easy fix. Replace the timer. The timer drive motor or gears inside have failed. Their are 2 styles of timers. Plastic type base and a metal type base. The plastic timer has a hollow shaft. A plastic rod with a rounded tip is inserted into the hollow shaft to hold the timer knob in place. To remove the knob and skirt on these you simply yank out the rod and the knob will come on off. Then you can yank off the skirt (dial Indicator) and the timer mounting screws will then be revealed. The other style has a threaded shaft in which the knob will unscrew and the skirt can be removed so you can get to the timer mounting screws. A big old molex type plug goes into the timer. You yank that out and look for corrosion before buying anything AND make sure that plug is in there tight because it can vibrate out.
Video how to get into the machine service manual and more fun stuff is HERE
Posted on Jun 02, 2011
Whirlpool Washer lsr5233a
Well sounds like a new timer is needed or timer motor - but these mechanical machines are difficult to diagnose as they dont give fault codes. The timer is a mechanical part and subject to wear and tear - cogs and motors wear out. Modern electronic machines don't have this problem, and timers are very expensive and difficult to fit for an amature. How long have you had the machine? I know top loaders last longer - but maybe time to upgrade to a new one
Jan 02, 2018 | Whirlpool Washing Machines
Kenmore 90 plus machine, top loader. the machine fills with water and agitates. It does not stop. The knob stays on the initial timer setting
Jun 02, 2011 | Kenmore Washing Machines
The timer dial has to be pushed in manually to get it to engage the gears (really hard to do). Now when we pull it out, the water does not come on.
The timer knob and or the timer may need replacing here is a link for checking and replacing http://appliancehelponline.com/topwashertimervideo.html
The inner knob teeth tend to wear off on the ge top loaders, so check that first. You might have also broke the screw tabs that hold the timer in place from having to push it hard.
Aug 02, 2010 | GE WDSR2080D Top Load Washer
Kleenmaid top loader replace timer
Apr 07, 2010 | Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Timer knob identification
hello here's a part list sight if you have your old knob you can match it here and order the part without knowing the part # Therese also lots of other useful stuff on this sight hope this helps
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?s=b6a11c251
please rate this post
Mar 15, 2009 | Washing Machines
Replacing timer
Jun 29, 2008 | Frigidaire GLWS1349A Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
