Question about Gateway Computers & Internet
Replace 120 mm case fan - Gateway Computers & Internet
  • 37 Answers
Quite simple, unplug the power lead from the power supply or motherboard. Then you will need to unscrew 4 screws that hold the fan in place. Install a new fan. Screw it into place like the previous one was and plug in the power lead.
Posted on Jul 10, 2008
Fan blade cracked
Replace it. Warranty if still in time and not due to bad installation or error. New purchase otherwise. Do not run the fan with a cracked blade or the computer without a fan.
Feb 12, 2014 | Antec KUHLER Shelf 120 mm PWM fan...
Replace fan belts
a few metric open end wrenches in most cases there is nothing bigger than a 21 mm so if you have 8 mm to 17 mm wrench set your set
Nov 22, 2013 | Toyota Land Cruiser Cars & Trucks
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Compaq presario desktop sr1503wm fan at rear of cpu box won't turn. can it be fixed or replaced? apparently the other fan is overworking and causing a loud buzzing which goes off and on again every few...
If it is the fan in the power supply, replace the power supply.
The case fan is easily replaced. Measure it (in mm) and purchase a new one. The standard fan is usually 40 mm, I think.
Oct 07, 2010 | HP Compaq Presario SR1503wm PC Desktop
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Will a 450w psu support....ati 5770, four 80mm fans,one 120mm fan
Yes you can do it. Should be no problem i used to have 4 accessory fans hooked up to a 450 watt power supply to keep my box cool, but i am also into gaming so need to keep things cool.
Apr 24, 2010 | Computers & Internet
Auto restart
It may be overheating or the power supply may be failing.
Jun 22, 2008 | Microsoft Windows XP Home Edition
Upgrading SR2010NX
Processor and ddr2 work fine as it comes to fan you have to know what kind of fan it uses 80 mm or 120 mm.
Jan 31, 2008 | Compaq Presario SR1050NX (DW257A) PC...
What size vent?
It looks like there is a 120 mm fan in there already, along with 3 others.
Here is the specs.
http://www.nzxt.com/products/lexa/
Jan 04, 2008 | Computers & Internet
Compaq case fan
more than likely 80mm ... measure its diameter with a ruler that has mm on it.
Oct 22, 2007 | Compaq Presario 1626 Cooling Fan Case...
Computers & Internet Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
