Question about Sony Playstation 3 (PS3) Console
How to pair futuretronics ps3 mini remote - Sony Playstation 3 (PS3) Console
Instructions for sony bd remote control
You can also plug in your Keyboard/mouse (any usb type keyboard and/or mouse will work with a PlayStation 3). That will allow you to navigate the PS3 XMB Menu, as follows:
1) Prepare the BD Controller.
2) Go to: (Settings) > (Accessory Settings)...
3) Select [Register BD Remote Control].
4) Follow the on-screen instructions to register the BD remote control.
When the registration, or pairing, is complete, your system will assign a controller number to the remote.
Hints
  • You can register only one BD remote control at a time. If you register another BD remote control, you will overwrite information on the currently registered device.
  • After you reach the maximum of seven active wireless controllers, you cannot register or use a BD remote control.
  • Registering the BD remote control with another PS3 system will clear the device registration from the first PS3 system.
  • For details on the BD remote control, refer to the instructions supplied with the remote.
Jul 24, 2012 | Sony BD Remote Control for Playstation 3
My pl-6309 wireless controller does not connect to my 160gb ps3 how can i get this to work.
You would need the USB charging cable that usually comes with remotes or PS3s. Its a standard USB on 1 side and mini plug on the other that would fit inside of the controller. With your TV and your PS3 on you plug the controller in and it should pair up to the PS3 with in a few seconds.
Feb 10, 2011 | Video Game Consoles & Games
My ps3 is not pairing with my remote and when i hold start and enter down nothing happens
I solved this problem by taking the batteries out of the remote turning the power off the ps3 for 5 mins then put the batteries back and turned the power back on to the ps3 and went to the settings and paired it up sorted
Dec 19, 2009 | Sony Blu-ray Remote for PlayStation 3
Need instructions for my ps3 sony bluetooth bd remote
nope. go to the ps3 setting part and into accesory settings. press bd remote. and follow the prompts. it is that simple.please rate
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Problems to register (pair) the BD Remote Control PS3... I press START + ENTER but not recognize... :-(
Be sure to only press enter and start. I was accidentally pressing the direction ring that surounds the enter key. This was preventing the pairing from working. You must press the enter key with your finger nail.
Sep 16, 2009 | Sony BD Remote Control for Playstation 3
I a playstation 3 Blue-ray disc remote control which wont pair
Go to Accessory settings in the PS3 Settings menu,which will have you register/sync the BD controller with the system. Follow the onscreen instructions &it will give the controller a #. Remember that any universal remote wont work..it has to be the Sony PS3 remote, as they use bluetooth technology instead of the usual infrared.
Jun 20, 2009 | Sony BD Remote Control for Playstation 3
Nre Sony BD/Playstation Remote Control won't register with my 80GB PS3
yeah to pair your rmote you have to register it in the
Settings then go to
Accessory Settings then go to
Register BD remote control not Manage blue tooth devices like PS tells you to.
then do the whole start enter scan bit
Dec 24, 2008 | Sony BD Remote Control for Playstation 3
Ps3 remote
which remote the controller or the remote to control the bluray and stuff. If its the controller just plug it to the ps3 with the usb cable then press the ps button. If it's the remote for the blu ray. I'm pretty sure you just have to go the the "Accessory Settings" and find the option to pair devices. Make sure the remote is in the mode where it searchs, check for that in the booklet, and there may even be a code you have to put in the ps3 (possibly '0000') or whatever it may say in the booklet.
Oct 10, 2008 | Sony Playstation 3 (PS3) Console
Play station 3 dvd remote pairing instructions.
OK I FIGURED IT OUT!!! First turn off the system(ps3) make sure that you take the batteries out of the remote. Then when you turn it back on go straight to system setting, setting accessories, setting blue tooth device. AND THEN IT WILL TELL YOU TO HOLD DOWN THE START AND ENTER BUTTON DOWN!. Don't forget to put the batteries back into the remote. It took like 3 seconds.
Jun 20, 2008 | Sony Blu-ray Remote for PlayStation 3
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
