Question about Cameras
Traveler camera super slim xs7 the lens is stuck in the open positiion the battery is fully charged i removed the battery and replaced it but did not seem to reset it when the power button is pushed the green light first lights up for a few seconds the display screen is black then the light turns red a few more seconds later the red light goes out
  • 3,083 Answers
It sounds like the shutter is stuck. You can try to spray some compressed air into the lens assembly, to free up any stuck gears (dust and dirt get inside and jam the gears up). You can also try to tap the camera on a palm on a hand, in case the gears are jammed. Other than that, the camera will need servicing. Get an estimate first, since the cost of repair can be high.
You might contact yor camera support service to see what they can do for you.
Good luck, and hope this helps.
Posted on Dec 31, 2010
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Cameras
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Kodak M1093
It requires service or repair
Sep 05, 2017 | Kodak EasyShare M1093 IS Digital Camera
Lens stuck open will not retreat battery fully charged when it is turned on lens moves in and out but will not fully close
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 20, 2009 | Olympus FE-280 Digital Camera
Olympus Mju mini - lens cover will not open
check out first if the battery is fully charged.and if the battery is very old.then prefer replacing the battery instead of charging.and if the battery is new,then the cover of the lens must be getting stuck up so try tapping the device from all the sides it will automatically get opened.also off the camera completely and try to move the lens door manually up and down.sometimes the gear assembly gets stucked and this makes it free to  move.
Nov 29, 2008 | Cameras
Repair stuck lense
try to take out the memory card, the battery again.
is there a error message ? was it in water/sun for to long?
try to see if there is something stuck in the lend, like send or dust.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
Lens error
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
LENS DOESN'T OPEN
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
By the way, try Fix #1 first with different fresh batteries.
Dec 10, 2007 | Olympus FE-230 Digital Camera
Cameras Logo
101 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
