Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
The batteries of my powersafe TR 36 are dead and I don't have any key. What can I do to open the safe? Urgent! Thank you in advance!
I know this post is months old, maybe you didn't open your safe yet or maybe someone else could use the advice.
The batteries are no inside the safe because of this reason, that you should be able to change them if they run dry.
Under the key panel is a long plastic panel. You can slide it to the right and underneath you find the battery compartment.
4 x AA batteries
Posted on Apr 30, 2011
  • tr_laptop Aug 31, 2011
    There is No battery compartment under the panel on the elsafe s30
Zoek 2 sleutels voor mijn safe nummer op mijn plaatje is type 36
nummer 00048996
Posted on Apr 20, 2016
S E
no number code !!!
Posted on Mar 26, 2013
My batteries are dead and can't find the keys so how do I open my safe
If you can't find the key you may need a lock smith
Oct 28, 2014 | Home Security
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
I HAVE A SURESAFE20ES; BATTERY IS DEAD; WHERE DO I OPEN TO CHANGE THE BATTERY? IT'S PRETTY URGENT
You need to charge the battery...not change it. If you can get a charge into it try a factory default code like 7777 to try to reprogram the safe.
Jul 04, 2012 | Cars & Trucks
Batteries dead and no key, has number 883203 on it, perhaps model number, help please as i don't know how to get in to put new batteries in and no instructions
If the container is locked with dead batteries to the electronic lock and no key then you wont be abel to replace the batteries as they have to be replaced from the backside of the door. It was a common problem that I would run into when I worked as a service tech and the only option is to drill the container.
Jun 21, 2011 | Safe International Electronic Digital Safe...
Digital safe. combination isint working. key was lost years ago. urgent that get open grocery money is inside.
I assume you have been able to open it with the key code up till now?
Its possible the batteries are flat. Most digital safes only have access to the batteries once it is open.
If you can access the batteries from outside try replacing them.
If the safe is only a cheap model use an angle grinder to cut it open, or take it a locksmith.
Good luck,
Steve
Oct 12, 2010 | Computers & Internet
Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
May 09, 2010 | Safe International Digital Electronic Safe...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Can't open my safe
https://www.sentrysafe.com/customerCare/replacementKeys.aspx
Here is where you can get a key to open your box! I think this will
FIX YA!
Please rate this free response
Thank you!
Jan 16, 2009 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
3,262 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
