Question about HTC F3188 Smartphone
How do i delete the storage applications if i reseted the factory settings?
  • 52 Answers
Just go to application and press the option botton and delete it
Posted on Dec 30, 2010
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
Feb 12, 2018 | ZTE Cell Phones
Reset zte maxx
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Nov 28, 2016 | Tablets & eReaders
How do i return my sidekick 4g to factory out of box state
Here are two suggestions and remember to backup if necessary.
T-Mobile Sidekick 4G Factory data reset:
1. On the main home screen, select menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if prompted, then confirm by selecting Erase everything (Note: If a Password was never set, it may be your last digits of the phone number or zero's)
T-Mobile Sidekick 4G Hard reset, this may help if the phone experience some hang or frozen on some applications:
1. Turn the phone's power off. Take the battery out from the device, wait a couple of seconds and reinsert it back again.
2. Now, Hold the Volume Down button
3. Then press and hold the Power button until the device turns on
4. A menu will show up like: Fastbook, Recovery, Clear Storage, and Simlock
5. Just select Clear Storage by pressing the Volume Down button
6. Then press and release the Power button
7. Select Volume Up if YES and Volume Down for NO
Once the reset process is complete, the phone will then reboot to its factory fresh state settings.
Any data including third-party applications previously stored from the HTC Sensation already wiped or deleted.
Jul 13, 2012 | Samsung Sidekick 4G T-Mobile Smartphone -...
Htc phone is freeze
Hi
Try soft resetting your device by:
Using your Stylus to press on the Reset button at the bottom of your phone.This restarts your phone.
Solved?
Then try a hard reset.This deletes all your data and third party applications and restores the phone to its original factory settings.Its advisable to first save your data/downloads on a secondary storage device.
Hope this helps.Thanks!
Feb 27, 2012 | Computers & Internet
Every so often my thunderbolt will crash and reboot for no apparent reason. Is this normal or a malfunction with the phone
There are a lot of software issues with some applications that lock up the phone.
Try deleting newly downloaded applications and work backwards until your phone does not reboot again. Any paid for apps can simply be re-downloaded through the Android Market.
If this does not work, attempting a factory reset will be your next step.
Factory Reset
1) Make sure you back up all of your contacts, pictures, etc. Factory Resetting could possibly delete all data off of your microSD card, and you wouldn't want to lose any of it.
2) Once done, from the home screen tap the Menu key.
3) Tap the Settings Option.
4) Under Settings, tap Privacy
5) Select Factory Data Reset
6) Tap Reset Phone.
Once done, your phone should be restored to factory defaults.
If for some reason your phone has decided to continue crashing and rebooting, you must perform a Hard Reset. This will undoubtedly remove contact information.
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
Remember, everything will be lost from this point on; so be sure you have EVERYTHING backed up that you do not wish to disappear. This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
Master reset
Factory Reset procedure: this can only be done if your phone is not FROZEN.
1. From the main home screen, select Menu
3. Select Factory Data Reset
4. Select Reset Phone
5. Enter your password, then select Yes to confirm
Hard Reset Procedure:
1. Turn the device power off. If your phone is frozen, pull the battery out and reinsert it back
2. Hold the Volume Down button
3. Press and then release the Power button
4. A menu will appear that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Just Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button again
7. Select one of the option then confirm: Volume Up for YES and Volume Down for NO
Once the wipe is complete,Your Samsung Vibrant will reboot to its factory default state settings.
All your data including third party applications on your phone already deleted, you need to reinstall it all back again.
Sincerely,
Eury Satorre
May 13, 2011 | Samsung Cell Phones
I am continually getting a low storage message in the corner of my phone even though I have deleted apps. It contiues to pop up.
Check the games you have installed on your phone. Some games use up a LOT of your phone's internal memory and some have the option to save most of the data on your SD card instead of the phone's internal. Go to settings > applications > manage applications to see which ones are using the most. I would try to delete some of the games then check the internal afterwards.
If that doesnt work you could always do a full wipe of the phone's memory (wont delete the SD card memory) by going to Settings > Privacy > Factory data reset.
Mar 11, 2011 | HTC Hero Smartphone
Master reset code galaxy s
How to hard reset the Samsung Galaxy S
We show you how to factory reset the Samsung Galaxy S to clear all data and restore its original settings
Published on Jun 3, 2010
The Samsung Galaxy S is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again. Here, we show you how to hard reset the Samsung Galaxy S with step by step instructions.
Please note that all data will be deleted from the Samsung Galaxy S as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Dec 11, 2010 | Cell Phones
Unlocked Samsung Behold can't make or receive calls
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature; everything is deleted. Nothing stored on the MicroSD will be affected, but applications will be deleted. Your Social network and contacnt information is automatically backed up to the MOTOBLUR server and will be restored when you login with your user name and a password.
  1. Factory Data Reset
  • From the screen of your phone, open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  • Tap Settings.
  • Scroll down and tap SD and Card Storage.
  • Scroll down and tap Factory Data Reset.
  • Tap Reset Phone.
May 10, 2010 | Cell Phones
HTC F3188 Smartphone Logo
20 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
