My servis m6705(3 years old)has blown the fuse in the plug,i changed the fuse now it wont start,any suggestions?
  • Washing Mach... Master
  • 1,527 Answers
Hello it might have blown the fuse inside washer it will be in the power supply
regards
shaun
Posted on Dec 30, 2010
1992 chevy cavalier rs. dash lights stopped working. car wont turn over. changed a blown fuse under dash . but still wont start
If the fuse blew, it may have been a symptom of a larger problem with your electrical system. I'd suggest testing your spark plugs, distributor and alternator, as well as jumping your battery. If it's not cranking at all, one of those should be the problem. A voltage multimeter is the tool to use; Walmart and AutoZone have them for $10-20.
Aug 31, 2012 | Cars & Trucks
My subs wont work and i dont know why...amp is on, fuse is good, car speakers still work but the subs wont...any solutions?
depending on how old your subs are you may have blown them over time depending on how loud you have them the spiders will start to ware out eventually giving way leaving you with a blown speaker. I suggest that you open the casing an removing the woofers if they are plugged in and pushing very gently on the spider located underneath the cone. if they separate then you will have to replace your speakers otherwise check to see if the woofers are properly wired first.
May 15, 2011 | Car Audio & Video
MY VP42HDTV WILL NOT DO NOTHING WHEN I PLUG IT IN WHAT COULD IT BE.
Hi if you plug it in at the mains and switch it on and you get nothing not even the standby light then this points to either a fuse been blown so check the fuse in the plug failing that it will mean getting a new power board fitted, now if the telly is more than say 2 years old i would say its not worth getting fixed as the chances are you will replace the power board and then you will start having problems with the inverter, soyou could end up throwing money down the drain.
if its less than 2 years old and its totally dead check the fuse in the plug change it anyway and then give it a try but if its still totally dead then this points to either the fuse been blown in the telly this is a little clear glass fuse located where the mains cable plugs into the main power board, if this fuse is not blown also then the whole power board will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Vizio VP422 42 in. Plasma TV
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
Truck turns over but wont start
check for spark, check for fuel, check fuses and relays, replace old oil,old fuel
Sep 20, 2009 | 1997 Chevrolet S-10 Pickup
No power
unplug the machine; using a meter check for continuity from plug end to control board/motor control
Jun 09, 2009 | GE WPXH214A Front Load Washer
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Dec 14, 2008 | GE WPXH214A Front Load Washer
Open Questions:
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
