Question about Coleman Heating & Cooling
My central air unit keeps freezing up on the inside
    Problem Solver:
  • 11 Answers
1) locate the A-Coil (A-frame) inside the furnace. It is usually located in the furnace supply plenum located on the "down" side of the furnace plenum. If it is very dirty, there will be poor air flow generally in the house. This can cause the A/C to "freeze up" as the refrigerant is not getting enough heat to convert the refrigerant to a gaseous state.
2) The unit may be low on freon (or whatever refrigerant you are using). Contact a serviceman to check the unit.
Posted on Jul 08, 2008
shastalaker7
  • 1515 Answers
SOURCE: i have an 80,000 btu ruud furnace and a trane
Hi, here are a few things that will cause a unit to ice up, and I see you have checked some, but I will go through it. Not enough air flow across the indoor evaporator coil, a dirty evaporator coil, lets say the filter had not been changed by the previous owners the dirt will cave the filter in and collect a sheet of dirt over the coil. This is the hardest coil to check and clean, but I have cleaned many of them to stop the ice build up. You say the unit has been cleaned. As far as the fan motor, it must be plugged into the high speed terminal on the circuit board in the indoor unit. This motor that was replaced should have 3- speeds. High is used for cooling and low for heating. You will see the other leads wire tied together out of the way. Colors depend on the motor for speeds, but will tell you if you are able to slide the blower out enough to see the data plate on it. White or yellow are normally L-1 or L-2, speeds are normally blue, red, and black. The wires may also be marked for what speed they are. Look on your board and you will see where the wire for the blower speed connects, it will say HI and LO. When you check these, turn it on and you can tell if the motor is running higher or lower then before. It will switch over speeds automatically to heat when its winter through the board. Motors are different in wires they use for speed colors or I could tell you, and its not the oem motor ( factory ). Blue is normally med., low is red, and high would be black, but like I say, yours may be different. Anyway, the speed, dirty coil, low on freon charge is # 1 cause. Also, make sure you don't have another filter somewhere in the home ceiling or in the retrun air stream somewhere hiding. If you were able to put a set of gauges on the unit, it would tell you right away if this coil was dirty enough to cause it to ice as the low pressure would be down to around 30 p.s.i.and a normal head. Low on freon would be a low high side and low side pressures. Check your suction line at the outdoor unit, the insulated larger of the 2-lines for ice. If you have ice there when all is melted off first, and it starts to ice there, its probably low on charge. You have a 80,000 btu furnace, but if you look at the model number on the outdoor trane, it would tell me the size of it. You will see a number such as this, 024, 030, 036, 042, 048, and 060. This will tell you the tonnage of the condenser trane unit. Here's how to figure it. There are 12,000 btu's per ton of cooling. Look at the numbers and find yours. multiply 12x2=24 a 2- ton unit, 30 a 2 1/2 ton, a 5 ton unit would be a 060. I just wanted to teach you more then anyone else will no unless they were a service tech. Why I wanted to no the tonnage is to know if the unit has a TXV ( Thermostatic Expansion Valve ) for metering freon into the coil or a fixed device. If the TXV happens to get a restriction, it will cause the indoor coil to be starved of freon and not flooded as it should be and ice up. This is rare unless at the factory when brazing a tiny piece of solder is floating around and plugged it up. I have seen this. About all that you can do on your own, is to make sure the fan is on high. The connectors at the ends will have a plastic cover over them to prevent shorts. All you need to do is unplug 1-wire and plug another in. If not sure, do each one from motor and test by hearing. You may have a door or panel switch on the perimeter that will kill power when removed. If so, tape it down to restore power. Make sure the indoor coil has no insulation stuck on it, this happens, the new blower motor is OK. The best way to de-ice a coil if you have a gas furnace is to turn on the heat! This will melt the ice off very fast so you have flow again until you find the problem. This is when you want to check the outdoor lines when all is defrosted. If it starts to ice when you turn it on, more then likely you are low on charge. I am sorry for such a long solution, I do this to try and teach the owner a little about there units and how they work. Please be kind when you rate me, this would be very good of you. I will be here if you need me. Keep me posted.
Sincerely,
Shastalaker7
PS If at all possible, make sure you have no return air ducts that have been flattened by a cable man or phone man. This is a big problem here where I live. Thay will put there knees on it or crawl on it and restrict the air coming back causing it to ice also. Think back if any one was under or in attic, where ever they are. Also, cats will rip them open and other critters. Just covering all the bases.
Shastalaker7
A/C & Heating Contractor
Posted on Jul 02, 2010
22yooper
  • 828 Answers
SOURCE: My AC unit keeps freezing
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
Posted on May 09, 2008
docjohn174
  • 943 Answers
SOURCE: coils freeze up inside the
hi thanks for the question i would check the air filter very important very important most common problem also check the drain from te evaporator it could be clogged thanks the appliance doc
Posted on Sep 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: central air conditioner doesn't cool
The capacitor is located inside the control panel on the outside unit. It is round or oval and silver in color.It runs the outdoor fan and the compressor both.
The terminals are marked= C, /F or fan/, H or herm. C-F-H.
The microfarad rating is printed on the capacitor. Make a color code wire diagram before removeing wires.
Disconnect power to the unit. Use a insulated screwdriver to short out the terminals on the capacitor before removing it.
Posted on Apr 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: central air freezing up
Low freon causes this problem. It could be the compressor going bad, but 99% of the time it is that the freon is low, have it leak tested and also have freon added
Posted on May 23, 2009
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Why would unit be leaking water on the inside unit
If it is leaking on the inside (coil) it usually is a sign the condensate drain is plugged causing overflow, or the coil is freezing up inside and when its off it thaws the ice and melts down the center of the coil and onto the floor,
Jul 21, 2014 | Ruud Central System Air Conditioner
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
My air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
Jun 25, 2009 | Heating & Cooling
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Lines freeze in central air unit
If you are not certified to do H V A C then I highly recommend that you call in the pro's. However there is something you as a homeowner can do. Start by checking the air filter. if it is too dirty it will slow the air flow across the coils and cause the coils ti ice. The line freezing is a sign that your coils are beginning to ice or already have. This is also true if the coils are dirty. You can check this by removing the air filter and using a flashlight to look up inside of the air handler. If they are dirty then you can clean them with a solution of water, mild dish detergent and a soft bristle brush. Be sure to rinse them thuroly. If this does not fix the freezing problem then you may very well have a small leak and need to have some refrigerant added. hope this helps. Good luck.
May 11, 2009 | Heating & Cooling
Rudd model ubhk-24jinfg
Check your filters inside the furnace, replace if needed. Then check to ensure that the fan is running inside the furnace. If these two things dont fix the problems, I would imagine you have low refrigerant issues. In that case you should call a service company.
Hope this helps ya please rate me.
Jun 20, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
173 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
