Question about Sony LMD-1410 14" LCD Monitor
How to restore default settings of sony lmd 1410 lcd monitor
  • 11,361 Answers
Here is the user manual:
http://pro.sony.com/bbsccms/assets/files/mkt/med/manuals/lmd1420.pdf
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
Monitor does not come on
Here one possible solution (1.) Allow the monitor to power off several hours to cool off. 2.) I changed the AC adapter because it seemed the plug was loose. Sometimes its a faulty AC adapter. 3.) I changed the power settings to Never Off. You can try Restore Default for monitor settings.
Dec 29, 2013 | Acer X183H 18 inch LCD Monitor
Lc? monitor
I think you need to degauss your monitor settings to remove these lines. Usually these lines can be removed easily in the CRT monitor setup but as for the case of LCD monitor they are cause due to array of dead pixels. Show it to a good technician for an immediate fix. breastfeeding pillow
Jul 06, 2013 | Computers & Internet
Lmd 9050 menu button doesn't work
you will need to remove the back cover to access the button panel board. then check for a loose connector, if ok check for an stuck up switch in the button panel.
Nov 15, 2012 | Sony LMD-9050 Monitor
I have a Sony 1410 LCD monitor, when it is powered up the screen displays vertical coloured lines on the left hand side for about 60 ml wide and the remainder of the the screen displays grey and black...
In most cases, this could be due to two factors. One - Your video card is losing life. Two - Your Sony monitor is almost dead. Simple way to trace the root cause is - borrow a monitor from your friend or someone and check. If the borrowed monitor works fine - it is the video card, that should be changed. Else, go for a new monitor.
Lastly, often people forget to check the cables. Sometimes broken pins or bent pin at the connectors could cause the problem too.
Mar 04, 2011 | Sony LMD-1410 14" LCD Monitor
Is this dell compatible
If your video card outputs Analog Composite, Y/C, Analog RGB and Analog Component Signals, then yes.
These are more like monitors you would find at a TV station for monitoring video feeds and the such, not so much for gaming or PC use.
Jun 27, 2010 | Sony LMD-1410 14" LCD Monitor
Two little yellow boxes on my screen
How small are the boxes? If they're extremely tiny chances are what you're looking at are called pixels and they're stuck. There are several ways to fix stuck pixels, try the ways listed here- http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
or
http://www.jscreenfix.com/
If it's not a stuck pixel(s) try resetting your tv to default settings by selecting ' restore factory default ' or ' restore default settings ' in the tv's menu.
May 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen is sideways--reading horizontally, not vertically!
Traci,
Your cat probably enable your lcd monitor to a portrait mode. Go to your toolbars on the bottom R/H look for a graphic card settings and right clicked, then look for rotation settings and setting to restore to defaults. Well... hopes that's your case. Have a nice day!
Sep 24, 2008 | X2Gen MG19MY 19" LCD Monitor
Reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
May 22, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony LMD-1410 14" LCD Monitor Logo
180 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
