BLEND AIR DOOR ON CLIMATE CONTROL IS STUCK ON HEAT AND I CAN'T FIND IT'S LOCATION. I HAVE CONFIRMED THAT THE AC STILL CYCLES BUT THE BLEND AIR DOOR BROKE. CAN YOU TELL ME WHERE IT IS LOCATED ?
The heater and a/c blend door actuator motor is located behind the center of the dash just below the windshield. The steering column must be detached and lowered and the dash must be removed to access the blend door motor.
How do i get to the vent behind the glove box my A/C is going out not in just a little bit not heard
The blendoor is under the right passenger side of the dash.its elc and mech both up left of the glove box
Air
Temperature Control Blend Door Failure No Heat or no AC (dependes on
where door sticks)
In
all modern cars there is a tiny DC electric motor driven gear drive
that moves a plastic door that blends heated and cooled air from the
AC and the heater core, this is called (interestedly enough) the air
temperature control blend door actuator. The motor that moves this
door fails because the door starts sticking from warping, most common
complaint is no heat but it can be no AC as well. To replace these
parts (blend door and blend door actuator) you must remove the entire
dash from the car. Always have this problem confirmed by a dealer or
qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Air
where door sticks)
In
98 LINCOLN TOWN CAR, HEAT STAYS ON WHILE IN AC MODE
96 linc towncar stuck on heat 2. a/c was working great but kept hearing a thumping under or behind dash when a/c was on.thumping stoped a/c stoped.hearter works great. someone please help!
have 96lin twncar.heat works but a/c does not.hear a clicking or flaping from bottom center of dash right over center hump of car floor. ive un plugged a/c controls and plugged rite back a/c works 4 ahile n goes back 2 blowing heat. i have tooken all dash face pieces off but not the whole dash. do i have 2 take the whole dash out?
same thing with my neighbors 96 town car. he heard a clicking sound in the winter time with the heat on and now he wants his ac but it only blows hot. where or how do I change the actuator or blend door? need help. thanks step by step would realy help me out. I am tring to be a good sameritan but its not working LOL
