SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
SOURCE: Hi, Last night none of the Dimplex storage
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
SOURCE: Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
