Question about Fujitsu Siemens LifeBook C2220 Notebook
C2220 battery is dead. How much does it cost?
    Brigadier General:
  • 8,909 Answers
Http://shop.ebay.co.uk/?_nkw=C2220%20battery&rvr_id=191579876866&mfe=search
Try this ebay link
Posted on Dec 30, 2010
  • 2,296 Answers
Around $50 on Ebay plus postage depending on your location.
MY NOKIA C2220 SLIDER PHONE SAYS ENTER RESTRICTION CODE WHEN I TURN IT ON ANYONE KNOW THE RESTRICTION CODE IT HAD A ROGERS SIM CARD BEFORE AND INM TRYING TO USE A SASKTEL ONE NOW
You can get the restriction code for your Nokia 2220 Slide ( C2220 slide ) from TheUnlockSpot.com by selecting the country & network to which your phone is locked and then provide the IMEI ( press *#06# to know ) when it is asked and get the unlock code through mail.
After you receive the code follow the method below,
1 - Switch on your Nokia 2220 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2220 Slide.
3 - Compose #pw+CODE+7#.
4 - The Nokia 2220 Slide would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly.
The letter w appears if you press the button star(*) four times quickly.
The symbol + appears if you press the button star(*) two times quickly.
Mar 10, 2013 | Cell Phones
Need to access fan on fujitsu c2220
1) ALL power removed from the laptop. Remove the AC adapter (Charger) and Battery.
2) Observe Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
You will be touching the motherboard, and can Static shock a number of hardware components.
Advise you purchase an ESD wrist strap, and connect it's alligator clip to a good ground source.
Average cost of an ESd wrist strap is around $3 to $6.
Example;
http://www.radioshack.com/product/index.jsp?productId=2103245
{ I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
If the table you're working on has metal legs, connect to an unpainted surface on one of the legs.
If none of the above applies for you, at least place a large metallic object on the table, and connect to it. (Unpainted)
Perhaps a metal serving tray, or large metal knickknack. (Unpainted}
3) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available you can substitute with a clean egg carton.
Label each egg holder.
SOME screws look VERY similar to other screws. DO NOT mix them up!
{ For example: If you install a wrong screw in a hole you chance it binding up in the hole, halfway in.
Try to take it out, and you may strip the threads off of the screw, and the hole. If the hole is in the motherboard, you've GOT problems}
4) Make a record as you disassemble. A personal record is nice to refer back to in case you are interrupted.
It is also p-e-r-s-o-n-a-l, so YOUR information is more concrete for YOU.
Make notes, and drawings, and/or photos.
5) I do not work on Fujitsu laptops all that often. My service information is very small as for Service Manuals. However, through the years I've found all laptop disassembly, seems to follow a basic pattern
I'm hoping this information crosses over to your Lifebook C2220 Notebook PC,
http://mycapsules.com/disassembly/fujitsu-s2110/cpu
Looking at the photo you will see Step 1 of 29 above it.
To go to the next step click on - next - in blue, or press the p key.
Fortunately for the Lifebook models, the cooling fan can be accessed from the top of the motherboard.
The Keyboard, Palm Rest Cover, (Upper Case), and Static Shield, are removed.
The Cooling Fan is right there on the left. (Two Philips head screws are removed, then the cable's white connector is unplugged from the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 17, 2011 | Fujitsu Siemens LifeBook C2220 Notebook
My nokia c2220 board has been damaged is there any chance having a life to it anymore...!
Most keyboards once they break usually very difficult to repair. I would check for warranty status see if you can get a replacement.
-Please vote for me :D
Mar 10, 2011 | Computers & Internet
Cranks sounds like a dead battery but battery is charged wont start and will start if jumped by a truck battery
You may have a dead cell in the battery. Have you had a load test done on it. I use 300 CCA batteries and recommend them on all riding mower. They may cost a little more but well worth the cost.
Feb 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have just purchased a second hand c2220 it has 2 copies of windows on it how do i remove one can i do a formayt with my xp disc or does it need special because laptop
Yes, you can use your XP disk (assuming XP is already loaded). Just make sure to get a complete list of your drivers (from device manager).
Oct 16, 2009 | Fujitsu Siemens LifeBook C2220 Notebook
1st generation shuffle ....dead battery can it be replaced ?
Yes. The battery's can be replaced, assuming Apple still has them in stock.  I *believe* they use the same batteries as the newer versions.
However, the cost of the battery and the work to replace it, you're probably better off just getting a new shuffle.
Mar 19, 2009 | Apple iPod shuffle MP3 Player
Fujitsu Siemens LifeBook C2220 Notebook Logo
286 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
