Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is not spinning
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Dec 30, 2010
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
  • 4 Answers
SOURCE: Kenmore Front loader Washer Problems
Hi, I got this exact Kenmore washer from Black Friday.  They finally installed last week and the vibrations were way out of control!  I looked around the machine and inspected the installation manual after spending hours leveling the thing and finally figured out that most likely cause is the foam shipping part at the bottom of the machine.  I called Sears to come back out since I have a pedestal screwed on the bottom, trapping the foam.  They came out and didn't think it was the issue.  I asked them to take it out anyway, and sure enough it worked.  For the first time my machine is working just the way it should...I wonder how many washers were installed this way?
Tip: To confirm that this is the problem, if you push down on the drum from the inside of the washer, you should be able to make the foam squeak...there's your problem!
Posted on Feb 08, 2009
  • 1294 Answers
SOURCE: washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
I have a Kenmore which is the same as the Whirlpool. I dismantled the unit, it was only 3 years as Sears stated its was not under warranty. Upon review the stainless steel tub tripod assembly which is connected to the flywheel was cracked in three places which caused the knocking and vibration. Even though the warranty states lifetime on the Stainless steel drum, there is a ploy on words as the failure was not the stainless steel, so these machines are good for the scrap heap as the cost to replace the parts is more expensive than a new washer.
Posted on Apr 14, 2009
jsrock516
  • 5911 Answers
SOURCE: My washer won't drain (code F2)?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Jan 04, 2010
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
Apr 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washer front loader duet
if it makes no sound when it is to spin check the lid switch
if it sound like it is runing and should be spinning then check the pump for something in it
Apr 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
1,216 people viewed this question
Dan Webster
Dan Webster
Sal De
