Question about Compaq Computers & Internet
Not switching on with battery and adapter - Compaq Computers & Internet
    Problem Solver:
Im not sure wheather you tried to connect direct to power without a battery. if you haven't try it and see it works if it then you battery is dead. don't use it you may damage processor
Posted on Dec 30, 2010
I cannot turn on my Micro BR - its plugged in and has new batteries but still won't work Does this mean it's completely broken or is there some sort of stand by phase that may have initiated itself?
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Sep 06, 2010 | Boss Micro BR Digital Recorder
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
Not charging batteries
It sounds like you are using a 65 watt AC adapter or an Auto Air Adapter.
The system needs a 90 watt adapter to charge the battery while the system is on.
Jan 20, 2010 | Dell Inspiron 1501 Notebook
Computer switching between battery & AC power.
Hi friend,
You can release the battery then use the ac adapter for run the computer..if your computer is runing then you need to change the battery...
Jan 06, 2010 | Dell Inspiron 9300 PC Notebook
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
Batter AC constant switch back nd forth
several possible causes -- bad power supply (AC adapter, bad battery, bad connection to AC adapter, bad connection to battery - or both.
May 26, 2009 | Acer Aspire 5040-3810 Notebook
Laptop intermittently works with battery
The adapter does not have a switch. When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
When you boot up the laptop with the adapter connected and check the power setting from the Control Panel and if it indicates it is on battery power, then either the adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Replace the adapter if it is faulty.
May 06, 2009 | HP Pavilion zt1145 PC Notebook
Couldn't switch on my laptop;adapter light blinking !
Please take out the battery, and use the AC adapter to boot up only, then put the battery on.
If any abnormal situation occurs, please do a battery calibration as instructed in the manual. Adapter info:
Power problems with AC adapter
Step1 :
Please remove the battery first to verify the AC adapter's problem
Step2 :
Please check the power outlet on the wall by plug another device to the outlet
Step3 :
Please plug the adapter directly to the power outlet on the wall
Step4 :
Please make sure both the wires between the adapter to the wall and to the notebook are well plugged and the LED on the adapter is alight
Step5 :
Please check the power status indicator to make sure whether the notebook is powered on
Step6 :
Please make sure whether the CPU fan perform the testing run when the power is switched on
Step7 :
Please stick into the hardware reset button at the bottom of the machine and reboot
Step8 :
Please remove all of the removable hardware (exp. mouse, PCMCIA card, power adapter, battery, external drives, memory and etc) and install only the necessary components.
Step9 :
Please remove the AC adapter and re-install the battery
Step10 :
Step11 :
If possible, please change another battery to make sure whether it's the battery's problem
Step12 :
May 04, 2009 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
