Question about Garden
I have a McCullloch Garden blower powered bya McCulloch engine. the details on th Carb cover are:- N213 BVM240 99207N00116 The problem I have is that the engine will start but will only run for aprox,2 seconds and then it dies as if its running out of fuel. I have noticed that if i fill the tank, leave the filler cap offf and operate the primer I get bubbles in the tank. one of the pipes that run into the tank has a weight on it. Does that weight incorporate any kind of check valve and if so could this be the problem? Many thanks in advance. Phillip Ribton. email - ribton0@xlninternet.co.uk
    Top Expert:
  • Garden Master
  • 50,592 Answers
The line with the weight( filter) is the main line to the carby
the carby operates by a diaphragm driven by vacuum pulses from the rotating crank and piston movement
much of your problem will be from a diaphragm that has gone hard and not sealing properly
you can either replace the carby complete ( around ($25.00 on e-bay) or go to your local mower repair shop and get a kit to replace all the rubber in the carby or have them rebuild the carby
Posted on Apr 15, 2017
KMusselmann
  • 247 Answers
SOURCE: Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Posted on Mar 20, 2009
mamicheddy
  • 79 Answers
SOURCE: kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
Posted on May 07, 2009
SOURCE: Craftsman riding mower, 21hp B&S starts and dies
Try removing fuel bowl under carb and cleaning it. Junk and condensation can collect there. I had same problem. Did that and problem fixed.
Posted on Jun 20, 2009
  • 376 Answers
SOURCE: I have gas going into my oil. 17.5 Briggs solenoid on carb bowl
The problem is the float needle and seat are leaking. It is not shutting off the gas when the bowl is full. The bowl fills up, then runs down the intake through the intake valve into cylinder, past the rings into the crankcase. Fairly common problem. Just replacing the rubber tipped needle probably will not stop the leak. The pressed-in brass seat needs to be pulled out and a new one pressed in also. Possibly there is some trash or rust in the carb that has gotten between the needle and seat, but in my experience, it usually takes replacing both to fix.
Posted on Jun 25, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
I either need a rebuild kit or new carb for a 40005102 McCulloch blower. Where can I find a part number for both? Mike
hey MIke,
in my experience, 99% of the time, a professional cleaning and setting will fix your carb issues...take it tot he local McCulloch dealer.. or professional small engine guy.. he SHOULD know how to fix it... the only need to ever replace parts is they are broke or worn out... ASK for ALL your old parts if they replace ANY!!!!
Jul 31, 2017 | McCulloch Garden
Need diogram & parts list for a mcCULLOCH asb3206 backpack blower
You can get a diagram and other lists using the resources below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
Oct 02, 2014 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Can't get my blower to start
You'll need fuel, air and a spark. Check for each of these.
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
I trust this information has proven beneficial.
Nov 22, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Troubleshoot mcculloch leaf blower
Yes. I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Nov 21, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Zama C1u M35a Carb For Blowers P/n 322410
Probably so. I recommend contacting your local service center for assistance.
Contact us
User manuals
McCulloch Service
Nov 05, 2013 | McCulloch Zama C1u M35a Carb For Blowers...
Part that the rope fit on is broken I need this part
Contact us
User manuals
McCulloch Service
Oct 26, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
McCulloch GBV 325
You'll need to be more specific; and actually ask a question.
Contact us
User manuals
McCulloch Service
Oct 22, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
McCulloch 32cc gas blower model ct m 32 em What is the black base called that the carburetor sets on mine broke????????????????
One question mark is sufficient. Please refer to your owners/service manual for part identification.
Contact us
User manuals
McCulloch Service
Oct 12, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Blower runs temporarily with full chock then dies. It appears to be missing a screw atop the carb, there is only one.
Contact us
User manuals
McCulloch Service
Aug 29, 2013 | McCulloch 26cc Backpack Blower with Dual...
Replacement Spark plug for McCulloch Model BL30 Backpack blower
Yes, I am sure you can purchase one just about anywhere.
Contact us
User manuals
McCulloch Service
Mar 15, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
