Question about RCA RT2500 System
6800uf/16v Capacitor? To fix the sound issue in the RCA RT2500 System, if I replace the capacitor with the same size and volt (6800uf/16v) will the same thing happen again with the system? Should I use a 6800uf capacitor with a little more volts, say a 25v or 35v?
  • 31 Answers
You can use a higher voltage capacitors without problems its the value of uf that should remain the same. But sometimes you can use a higher uf like a 330uf can be replaced with 470uf but never go lower than the original value on uf and voltage. But you can safely use 6800uf 25v or 35v.
Posted on Dec 19, 2008
I have a D52W20 green light comes on 3 times but has no power.
Replace capacitors in power supply area
Replace capacitor cp150 (2200mf 16v ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V )
Thank you
Aug 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on
HI, thank you for visiti fix ya.
your solution is here. ( replace capacitor in power supply, 2200uf 16V, 220uf 16V ,33ouf 25V 100uf 16V), you will se capacitor vented or bowed.
Look the picture for best result.
If do you have question inthe future, I will be here.
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
Mar 14, 2008 | RCA RT2500 System
Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
Dec 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Audio With RCA RT2500
Hey EmperorBob, was reading a short across D119 & D120. pulled (I think it was) C139 and was able to get a good reading across the two diodes. reading a short on the cap (out of circuit). Still poking around. Will let you know if I find anthing else...
Nov 28, 2007 | RCA RT2500 System
RCA DRC257N No Power
Had the same exact issue. RCA DRC257N was acting funny, frequently freezing up at HELLO screen, sometimes buttons would stop working during playback, requiring frequent unplugging to get back to working. Opened the case, pulled out the power board and noticed that capacitor C411 (1000uF 16V) was bulging out at top and bottom. Replaced with a $1.59 1000uF 35V capacitor from Radio Shack and all is back to good working order. Thanks.
Aug 17, 2007 | RCA DRC257N DVD Player
Rca rt2500 rec
I'd suspect your power supply capacitors are on their last leg. replace them.  - This was posted by videoguy1742. :   this problem is CURED simply by replacing 2 capacitors inside on the main board. They are easily identified by a bulge on the top end of the capacitors. The capacitors are located between the heat sinks. The size is 6800uf/16v.
I am a RadioShack dealer and sold a few of these in 2000/2001. I bought one for myself. I have repaired only 2 that had the same problem as listed by HAGUC above. They both are working great and for the record. . .are NOT peices of JUNK,. . .hehe. . .they just need a little TLC. Parts available from larger electronics parts houses, not at RadioShack
Aug 08, 2006 | RCA RT2500 System
RT2500 speaker hum buzz until unit warms up
i have the same system that i bought new and after about 3 yaers it did the same thing for no reason. i think you get what you paid for!!!
Oct 20, 2005 | RCA RT2500 System
RCA RT2500 System Logo
710 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
