Question about Panasonic PT-52LCX65 44" HDTV
Yellowish spot on the lower left hand corner of tv screen
I have a PT-43LC-14-K tv. Six months ago, I changed the lamp on the tv and then about 3 months later, I noticed a yellow spot appear on the lower left-hand side of the screen. It started to slowly get bigger as the weeks passed by. Now, six months later, the lamp indicator has again come on and the "new" lamp appears to need replacing again.
My question is in connection with the yellow spot...why is it there? what caused it? I didn't see it at anytime during the life of our first lamp...my research suggests that these DLP televisions are NOT susceptible to burn in...so what's going on here???
Thanks for any help you can offer.
  • 927 Answers
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Posted on Sep 09, 2008
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
There is a yellowish patch of in the lower left hand corner of my screen, either to a fall or some other type of impact. Is this fixable, if so how much?
sometimes in this set foams comes apart inside and looks like a dark spot on screen in the corners, if you can open up then then look around the light engine.
Jan 15, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Blue images on lcd tv
optical block failure
Feb 22, 2010 | Televison & Video
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Light green and pink spots on my hd tv!!!
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
294 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
