Question about Apple iTunes
After installing itunes when i try to run it windows gived me a dep error tried to change settings in dep but that doesnt work
    President:
  • 2,291 Answers
ITunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Posted on Jan 10, 2011
When I try to play a big fish game I get the drm activator stopped working message...the game is midnight mysteries..curse of the raven or something like that..the solution involving checking windows to...
To fix this, go to: Control Panel > System > Advanced System Settings > Settings (under performance) > DEP (tab) and then add your program as an exception.
Aug 16, 2010 | Computers & Internet
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
Oct 30, 2017 | Konami Casino Inc. for Windows
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
Installing AVG 8.5 on Windows XP professional getting error 0xc0070002. What is the fix?
Your computer's processor blocked an activity of a program by stopping the computer from working to prevent the activity from being executed (also known as DEP or Data Execution Prevention) and giving such error instead.
Try turning off the DEP for all programs by:
- opening Start > Control Panel > System
- Click on 'Advanced' tab
- In the performance area, click 'Settings' button
- A new window will appear
- Click on 'Data Execution Prevention' tab
- Click on the upper radio button (run DEP only for Windows services)
- Restart your computer
If it doesn't work or is turned off for all programs already then there seems to be a problem with your Windows (since you said that IE takes 100% CPU process), or the antivirus program isn't really compatible with your hardware and/or driver software.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
Windows data execution prevention won't allow itunes to open!
ok try this then.
Press [windows]+Pause/Break to open the system menu (or control panel -> system) and press advanced systems settings on the side. Go to the advanced Tab, and press settings. Go over to the D.E.P. (Data Execution Prevention) tab, and press add, then add in iTunes and whatever else you need.
Oct 03, 2009 | HP Pavilion DV5234US Notebook Laptop
Itunes wont open
I would first try shutting down every process in Task Manager (hold down: Ctrl / Alt / Delete keys) that isn't necessary to run your computer. Next, if that didn't make it run properly, try installing iTunes while in safe mode. You'll have to consult your computer's instructions for entering safe mode. If that doesn't fix it, you may have to re-install Windows (I've assumed that you're running Windows).
Jan 22, 2009 | Apple iPhone Smartphone
Itunes shuts down when itouch is connected
you need to look up help on disabling DEP for itunes.
Jan 04, 2009 | Microsoft Windows Vista Home Premium with...
Ipod not recognized by computer or itunes
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Nov 27, 2008 | Apple iPod nano
Itunes with vista
From what I understand, iTunes is not recognizing the iPod, because Windows does not recognize it. Choose to install the driver, set it to search for a driver in "C:\Windows". It should find a USB Mass Storage Driver, an iPod Driver, and a USBusEnumerator. Choose the iPod Driver, and if that doesnt work, try the USB Mass Storage Driver, and then the USBusEnumerator. If Vista gives you a memory error, reboot your computer and try the iPod Driver again.
Apr 06, 2008 | Microsoft Windows Vista Ultimate Edition
Windows vista closes my program
Why is Windows closing my program? gl_icon_tip.png Applies to all editions of Windows Vista.
Which edition of Windows Vista am I using? Windows might close a program and then notify you if it determines that the program is either a security risk or incompatible with this version of Windows.
When Windows closes a program because of a security risk, it is because some programs might use your computer's random access memory (RAM) in a way that could be exploited by a virus and harm your computer. Data Execution Prevention (DEP), a security feature of Windows, tracks how programs use memory. If DEP finds memory being used incorrectly, DEP will close the program and let you know. If you trust the program, you can add it to an exceptions list so that DEP won't close it, but you should first check with the manufacturer of the program to see if there is an updated, DEP-compatible version available.
When Windows closes a program because of compatibility issues, it is because some programs could damage Windows if you try to run them. If Windows notices that an incompatible program might harm your computer (for example, by damaging important system files), Windows will close the program and notify you. Check with the manufacturer of the program to see if an update is available, or check Problem Reports and Solutions in Control Panel to see if a fix from Microsoft is available.
• Open Problem Reports and Solutions by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking System and Maintenance, and then clicking Problem Reports and Solutions.
If this dont fix the problem......... id re-store the computer with the restore cd that came with your computer. Good Luck hope this gets your computer back up and going.Please dont for get to Vote. Thank You.gl_head_str.png
Dec 11, 2007 | Computers & Internet
Apple iTunes Logo
209 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
