Question about Pioneer Car Audio & Video
HAVE TO SET RADIO STATION EVERY TIME UNIT IS SWITCHED OFF HOW TO SET PERMANENTALY . ALSO WANTED TO KNOW IF DISPLAY COLER CAN BE CHANGED
  • 3 Answers
For Pioneer car stereos to keep the station memory the wiring is as follows:
Yellow is 12v constant
Red is on with ignition switch.
Orange/white is for lighting switch.
as for display color, need to know the head unit model.
Posted on Dec 30, 2010
How to I change the radio stations associated with each of the buttons?
In the vehicles I have owned, I've tuned to the station I wanted and held down the numbered or lettered button until I hear a beep sound letting me know that it has stored it correctly. Then you could tune to another station and hit the button you just set. If it goes to the station you wanted to preset, viola! So continue to tune to the next station you want and hold the button down that you want the station set to (ex: button 1=92.3, 2=104.5 etc.) Good luck.
May 15, 2016 | Cars & Trucks
No radio display
Check your dimmer dial by the head light switch, it may be on the off or very low position.
I don\'t think a fuse would be the problem if the radio still works.
If not then you may have a bad display on your radio and it may be time to replace the radio for a kicking stereo you always wanted...
Nov 06, 2013 | 2011 Chevrolet Cruze
Code radio Audi A6 auz1z7p4729562
Press and hold (at the same time) the AM/FM and the SCAN buttons until the display reads "1000".
Use the station preset buttons 1,2,3,4 to change each of the digits to the proper code. Button 1 changes the first digit (on the left), button 2 changes the second digit, etc.
Note: supposedly the programmable units were originally coded with either "1111" or "1234" by the dealer. It is quite possible that the code was never changed by previous owners, so if you don't know the code, you can try these.
Press and hold the AM/FM and SCAN buttons again until the radio comes on.
If you fail to give the correct code after two tries, the unit will be locked in "safe" mode and won't change. To try again, leave it switched on for approximately one hour.
hope above work with u
Jun 18, 2011 | 2002 Audi A6
How to change the time on the Timex auto set clock radio.. the DST hasn't switched back to EST.
Timex T309TT Clock Radio.
Setting the time:
Unlike another review that says it automatically sets the time, I did not find that to be the case, I believe the model with the cd player does that, but this one had to be set. I'm not one to usually read the manual as I like to figure things out on my own, and was able to set the time without the use of it. It was as simple as holding the time set button and using the reverse and forward buttons to advance the time. Unlike some clocks, you do not have the option to change just the hour or just the minutes, you have to forward or reverse through all the hours/minutes.
Calendar:
The alarm can be set to go off 7 days a week, 5 days (Monday-Friday), or 2 days (Saturday & Sunday). Again, easy to do with pushing the date button and using the forward and reverse buttons to scroll through the dates.
Adjustable display: There are 3 levels of lighted display, pressing the snooze/dimmer button allows you to change between the three. Nice touch!
Radio Operation:
After pressing the Radio on the display will show the word "on" before returning to the clock display. The bottom display shows the radio frequency.
There are 18 programmable radio station settings with the buttons to access them right on the front of the clock labeled 1-6. Programming is easy with just finding a station you like and pressing and holding one of the preset buttons until it beeps to confirm it was accepted.
I find the radio to get fairly good reception and for the times it doesn't , after moving the attached wire antennae it would pick up a better reception.
So far my experience with the sound quality has been good.
The radio also has a last station memory, so after being turned off and then back on, will recall the last station you were listening too.
Alarm:
Setting the alarm is fairly simple. To set , simply press the alarm button until the time on the screen starts to flash. Then you can click the button to choose through 3 settings which are every day, weekends, or Mon-Fri. This radio also comes with nature sounds. I have not used this feature at this time. You have the choice of
* Ocean surf
* Forest spring
* Rushing brook
* Summer wind
Hope this helps :)
May 03, 2011 | Timex T309TT Clock Radio
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
Want time to show on radio display on 2003 325i
Set time and it will show on radio,providing its original radio
Switch ignition on,use scroll lever on top of indicator untill you see time
Reset and con firm using button on end off stalk
Jul 04, 2010 | 2003 BMW 325
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Car Audio & Video Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
