The plasma screen would turn on (green light) when ON-button pressed but then after a few seconds, light would switch to flashing red standby light (11 flashes). Pioneer says it sounds like it's a power supply issue (I think it's a common problem as seen on Fixya.com). Repair guy says I need to replace the X-Drive which is suppose to be a pc power board. Wants to charge over $300 for the X-Drive plus tax and $270 for labor. Does anyone know what exactly an X-Drive is? What would cause the X-Drive to need to be replaced? (how to prevent the same problem in the future) What's the average cost of an X-Drive, etc.
Before you call pioneer,you need to be sure your media box had plenty of ventalition on the back.
Secondly,if you could locate another connection cable(one from the media box to the tv)and have it replace your existing one and see if that works.
Once you have tried both troublshootings shown above with no result,at this point,you should call 1-800-pioneer.best time to call will be Tuesday-Thursday at 7am PST.
solutiondoct
DId you find anything out, I just encountered the same problem tonight.
I am having similar problem. Every time I turned on my TV it shuts off after 2 second and the green stand by light keep blinking in TV and also the Orange rec light keep flashing in Media Receiver. The TV used tuned on after many try and now it doesn't at all. Is this a problem with the TV or the Media Receiver itself. Appreciate if anyone can answer.
Hi
Did you find any solution. I Hve the same problem
Thanks in advance
