Question about Coleman Propane Grill Stove 9921-700
My barbecue ignitor came apart. How do i fix it? I have all the parts. ( the 2 springs, the red "trigger", another goldish metal piece, as well as the gray body of the lighter and black "collar" that goes around the red trigger area.
Weak spring goes first, then metal piece, then harder spring, then push the button back on.
Posted on Sep 01, 2008
  • 25 Answers
Buy a new one they are cheap.
Posted on Aug 19, 2008
How to open sony rmvlz620
I have a Sony RM-VLZ620T IR Remote Control.
This remote consits of:
(Outside)
- Two pieces of black plastic cover.
- A red plastic cover on the front of the Remote (It covers the IR leds)
- One piece of gray rubber stripe with fixing patents(!) around on the sidewall of the remote.
(Inside)
- One piece rubber sheet with the buttons.
- One piece circuit board with battery fixer metalic springs.
1. Removing the gray stripe.
Be gently to avoid to tear apart the rubber fixing patents. (There are three kind) It's much easier if you start from the back of the remote near the arc and move forward one by one. Use a small screwdriver or a plastic tool.
2. Opening the cover (together with gray stripe removal)
There are 5 rectangle shaped "holes" (~7mmx2mm) on the both side of the upper black plastic part of the cover (2x5). Use a screwdriver to lift them up (away from the bottom part) one by one from the back to the front.
Hole positions:
1. Near the sony logo
2. Next to the 1,3 channel buttons.
3. Next to the heart and info buttons.
4. Next to the record and stop buttons.
5. Next to the set and power button.
Dec 30, 2013 | Sony RMVLZ620 Remote Control
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
May 28, 2011 | McCulloch 1400 Psi Electric Pressure...
I am familiar with repairing paslode framing nailers. However, I am perplexed by my current scenario. It seems that the "stop" is not seated correctly. The "stop" is the small metal...
took one apart tonight. I think you have forgotten to put the spring in place that makes the pin go backwards. You can see it in the parts schematic. You can probably see the rub marks on th ein when you look at it.
Dec 15, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Mar 17, 2010 | Stanley Tools/Goldblatt Tool No.TR150 Hd...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Coleman Propane Grill Stove 9921-700 Logo
135 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
