Question about Yamaha RX-V1600 Receiver
Why is my yamaha amp is keep turning off? - Yamaha RX-V1600 Receiver
  • Yamaha Master
  • 17,129 Answers
Please check the inlet voltage from the mains.
Make sure the speakers are not short - test with a 1.5 cell- or with a multimeter for the resistance of the speaker coils. make sure there is no short in the wiring.
reduce the BASS, Treble to mid point and see if the amplifier works longer.check the input source or change them.
Finally help with cooling if kept inside any shelves.
Respond.
Posted on Dec 30, 2010
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
I have an old Yamaha amp which has not been used for 15 years & it now keeps turning the sound on &off
If the unit has sat that long chances are capacitor replacements are in order, overtime they deform until they become unusuable and can rupture when power is applied.
Aug 31, 2012 | Yamaha Audio Players & Recorders
My yamaha keeps turning off as soon as i turn it on...
Buy yourself a 120mm 12volt computer case fan and a 12volt power pack. Mount the fan with some double sided tape to the grill on top of your AVR. Have the fan mounted so it draws air out of the amp and turn it on when you know you are going to crank up the volume. Try and buy a fan with the lowest noise level so it isn't annoying
Dec 10, 2010 | Yamaha RX-V595 Receiver
Just bought yamaha rx-v467 reciever, it worked for 2 mins then it trips out, wired all surround sound correctly. now unit only turns on for 2 secs then turns off. it does it 3 times and then you have to...
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 09, 2010 | Yamaha RX-V463 Receiver
My yamaha P7000 always lights its protection lamp whenever turn on...
The amp will require service. One or more power transistors have failed and the protect circuit keeps the power supply from blowing your speakers
Oct 12, 2010 | Yamaha P-7000 2-Channel Amplifier
Amp keeps turnning off say to check speaker wires but speaker wires all ok i think
The amp turning off means you've got a shorted output, so I'd unplug your speakers, unplug the wires, etc, then plug it all back in, paying attention to the wires and where they're going.
Jan 08, 2010 | Yamaha 5" 2-Way Bookshelf Speakers (Pair)
Can you run 200watt 6ohm speakers on the RX-V490
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Nov 13, 2008 | Yamaha RX-V490 Receiver
Puchased A Yamaha DSP-A1092 Amp from Auction turns off
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Nov 13, 2008 | Audio Players & Recorders
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Jul 22, 2008 | Yamaha RX-V490 Receiver
Yamaha RX-V1600 Receiver Logo
172 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
