Question about Dishwashers
No water in wash - Dishwashers
  • 17,130 Answers
Make sure that the inlet has the flow of water- remove the inlet to check. when the program is triggered if there is no flow it is possible that the inlet valve is faulty specially if voltage comes on the valve without a function. Dirt could also be clogged in the valve- if so clean and reset. If there is no voltage then the program controller is faulty.
Posted on Dec 30, 2010
How do I maximize water levels in my whirlpool wfc7500vw washing machine? In other words, which cycle uses the most water, and/or how I can turn off the water sensor so that the machine uses extra water?
The water levels in you machine are set by a pressure activated diaphragm that is controlled by the knob with the levels settings around it or by the computer if you have a press button type.. Heavy or long wash cycles use the most water with light washes using the least. So to explain if you are washing blankets and you have a full 7.5 kg load to wash you would set the water level at high and heavy or full wash. You can disconnect the tube to the control unit but if you do that the bowl will keep filling over the top and the machine would not know when to start washing as the control unit reads enough water and moves the power to the motor while closing of the water solenoid. If you follow the instruction in the operators manual you will find that you save the most water at any wash requirement.
Jul 29, 2013 | Washing Machines
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Bendix washing machine....only washing in cold water-no hot water while washing
If you have selected a cool wash, then it is possible that it could be washing in cool water, if you have selected a hot wash, and it is washing in cold water, then I would suspect that the heater elelemnt is not working, you really need to test it with a meter to be sure.
Hope this helps you .
Dec 21, 2009 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
