When heat is called for,the burners only lite 2 seconds
  • 5,572 Answers
Hello, if we are talking about a gas or propane heater, there is a flame sensor in the burner mantle. Usually these look like a wire or small cylinder the size of a ballpoint pen cap. There will be usually 2 wires running from it. If the flame sensor is bad, it shuts off the gas because your furnace does not know it is burning. It wants to prevent a buildup of unburned gas so it shuts of the supply.
Another possibility, can be a part furnance guys call a "sailswitch". This switch is higher in the furnance well above the burners. You should hear a small motor run and this "Sailswitch" detects the airflow from the small motor and the rising heat from the burner. If this switch does not work your furnance will think the exhaust is blocked or the small motor is not running. It will kill the gas to the burner. Usually the small motor and "Sailswitch" must work before the burners get gas. Since you said the burners cut out after 2 seconds, a lag time is possible.
When you go to an appliance parts outlet, like Servall, have all the information about Model, Serial number, Manufacturing date, with you to obtain the correct part. I hope my info has been very helpful to you. You may want to obtain a new part first, which will help in identifying the old part.
Posted on Dec 30, 2010
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
Goodman gms80903bna light blinks once fan runs all the time,
I believe this code is ignition failure.
Turn power off and after 20 seconds turn power on with thermostat calling for heat. Vent blower should come on first. After a bit igniter should lite up. You should hear click noise of gas valve open up. If igniter does lite and you hear click noise, flame should come on for a few seconds minimum. If igniter doesn't lite and you hear click noise from gas valve, igniter is bad. If flame lites and then goes out, flame sensor probably needs cleaned. Both igniter and flame sensor are in metal plate under burners. Igniter has 2 wire going to it and flame sensor has one wire. If you think it is flame sensor you can remove with taking it out with 1 1/4" hex screw. Flame sensor will have white film on it if it needs cleaned, clean with steel wool or a dollar bill. If it isn't weither of these it is gas valve or circuit board.
Jan 27, 2011 | Goodman Heating & Cooling
Gas furnace blower fan blow iginition lite come on burner will not lite, if the burner do lite up they only stay on for about five seconds
Could be 1 of 2 problems:
1) Pressure hoses dry rotted or stretched. remove hoses at connectors and cut the bad ends off. Re-attach.
2) Flame sensor is oxidized. You can clean the sensor with steel wool. If that doesn't solvethe problem, replace the flame sensor.
Jan 23, 2011 | Heating & Cooling
Heater won't come on. It is calling for heat, but
A lite 2 will have a electronic ignition not a milivolt pilot generatot. This can be a couple of things, most have to do with the pilot. You need to remove the burner tray by removing the gas line after you shut it off. Then remove all the screws that hold it in place and pull it out the front of the heater. after you remove and label all the wires. The pilot assembly will be mouted to one of the burners. You could have other problems, spider webs in the gas orfaces, no signal through the wires, or a number of other problems and if you go just changing parts you could spend a lot of money. If you have your book read the troubleshootin guide first. But always remember this is a box full of fire next to your house. A profecional may be your best option. Good luck and let me know how you do.
Oct 22, 2009 | Jandy LAARS LITE 2 INDOOR DRAFTHOOD 175...
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars-lite LD 97-2000 pool heater wont burn
cycling usually begins as the result of poor water flow caised by debris in the pump, dirty filter or low water level. once you have had some cycling the heater burners and ignitor become sooted and this requires pulling the burner tray, de-sooting the burners and pilot and reassembly. unless you are very competent you may want to call a service tech. Pool heater repair is a high laibility endeavor if done improperly. During the certification class our instructor showed us several houses that were burned down from improper heater repair.
Mar 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
