Question about Samsung HT-Q70T System
Unlocking Disc Tray?
Hi, does anyone know how to unlock the disc tray on the Samsung HT-Q70T. I have the top off, and can't figure out how to slide the tray out. The unit is dead,Power Supply board has blown up components!!!
There should be an access hole under the unit where you can move the load/unload mechanism manually.
Posted on Dec 04, 2008
If you want to remove the entire tray, remove the top of the casing and the the front as well. The front is held on by a screw on top and two smaller screws, one on each side. Then remove this face plate by releasing the clips built into the unit, two on each side, two on top, and two bigger ones on the bottom. Try to just lay the face plate/front cover down beside the unit to avoid the effort of disconnecting the other pieces. Remove the two screws, one on each side, of the dvd laser top cover. Remove the two screws under that, one on each side, they're also accessible without removing the dvd laser top cover at all, but either way all four screws need to be removed. Remove the center screw holding the top of the tray/turntable. Then remove the turntable top, you'll have to pry this up near the dvd laser while sliding it around to get it past the two interlocks(inch wide lip overhanging) built into the tray bottom. This may not be necessary to remove, but it makes it easier to slide the tray out later. Next remove the two screws holding the tray mounting brackets in place, there is one located on each side near the front. You may only have good access to one side and should remove it first to give yourself more room to work on the tighter side. You may even be able to pull the tray out without removing that side's screw and bracket at all. The tray should slide out of the front then, like it does when it opens during normal operation. At least put the top cover to the dvd laser back on, and if you're wanting to reattach the top of the turntable, remember to do that first...before attaching the dvd laser cover. There may be one or more screws somewhere I didn't mention to remove, it's been awhile since I took one apart. And of course, don't look at the dvd laser and don't mess with the two 250v capacitors...they will still be charged and can shock you. They'll look like two black cylinders, side by side, each about the size of a C battery or a little smaller. Most likely you should be fine unless you remove the power supply board and make contact with the soldering points on the underside. Just try not to slip the screw driver and so forth. Hope this helps, it's about all I could remember, so look for other attachments, screws, etc if you get stuck.
Posted on Aug 17, 2008
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
I would like to make my player region free
there is a way to make your player region free - do the following:
I have a new HT-E3500 and did the following:
I have a Region B/4, player
I used the R4 code from below.
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
It needs to be done without delay. (consequently)
So if you don't get it to work straight away don't loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Nov 12, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
How do i change my region on my samsung HT-E3500 i am in mexico and can't view my dvds from the states
tengo la misma pregunta , lo he comprado en el palacio de hierro y no pudieron hacerlo multiregion , lo llevare a un centro de atencion a clientes , si se algo te paso el codigo o, o si tu lo sabes antes me lo pasas . Saludos
Nov 10, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
Samsung HT-E3500 region-free
I have a new HT-E3500, and after 20 minutes I got the following to work.
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running 080604.01_050708-1_XSA code.
Now it to me about 20 tries to get this to work, It needed to be done without delay.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jul 02, 2012 | Samsung HT-E3500 - Home theater system -...
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
Does anyone know who to make region 2 Samsung BD-P1500 player multi region ie play both region A blue ray and region 1 dvd?
Below is a known process to unlock your region settings. Not 100% surefire.
So if you don’t get it to work straight away don’t loose heart.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Post back and let me know if this works. Thank you for trying Fixya!
Apr 06, 2009 | Televison & Video
Unlocking of Samsung BD-P1500
I have a new BD-P1500, and after 5 Times
090417_01_BDP1500_XAX.RUF
Now it to me about 5 tries to get this to work, It needed to be done without delay.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Report this hack (requests/questions/spam/wrong/****).-->
Region code hack posted by wasgo, September 17 2008:
I have tried the hack mentioned above on my new BD-1500 and couldn't make it work. But the software in it isicon_minipost.gif about a month newer.
Does anybody have any new ideas how to solve the problem?
I have the region 2 version (Sweden)
Jan 18, 2009 | Samsung BD-P1500 Blu-Ray Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Samsung HT-Q70T System Logo
104 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
